05-19-2013, 10:54 AM   #16
Heie's Avatar
QuoteOriginally posted by Spodeworld Quote
@heie - one last thing. Do you notice better AF in low light. The k20d just doesn't cut it, and the k01 isn't dramatically better. I know that the k5ii/s is the way to go for low light focusing, but just wondering how you find the K30 in low light vis-a-vis the K5 classic. Thanks again. I was considering a used k5, but now am leaning towards a k30.
You sure just one last thing?
I haven't used the K-20d, but the K-30 is pretty good with low light focusing. I just did a test in my very dark room with the K-30 and K-5IIs with the same lens (DA 18-135 WR) at 18mm. The K-5 IIs doesn't hunt, but it wasn't fast in any regard - much slower than daylight focusing (which is damn near instantaneous - K-30 as well with the 18-135). What I found interesting though was that the K-5IIs did not turn on the AF assist light (I had to check just to make sure it was actually enabled), yet the K-30 did. With the AF assist light (green on both in case you are curious), the K-30 was very decisive, something I found interesting especially considering the beam was on the wall about 4 meters away. I honestly was not expecting it to lock at that distance, but it did.
At 135mm (which means the aperture went from f/3.5 at 18mm to f/5.6 at the tele end - significantly less light), the K-5IIs hunted, but still refused to turn on its AF assist light. Odd, indeed. The K-30 obviously used its AF assist. Both lenses locked focus when I placed the center AF point (which I used the entire time) over something of high contrast (i.e. a black picture on a white wall). Otherwise, they both weren't able to lock. Like I said, it is dark.
EDIT: hmmm, it seems that the AF light wasn't going on because it was in AF-C mode, not AF-S. Turning it back to AF-S yielded the AF assist light on the K-5 IIs, and it helped locked significantly faster than without the light. Without the light, the K-5 IIs wins handily, but with on both, they seem to focus about on par - the K-5 IIs maybe a tad more decisive.
Hope this helps
-Heie
05-19-2013, 12:16 PM   #17
Spodeworld's Avatar
Thanks again. Sounds like the K30's AF does well even in low light and I'm guessing better than the K-5 classic. Interesting info about the light not going on in AF.C as I often use it along with back button focusing.
Last edited by Spodeworld; 05-19-2013 at 12:19 PM. Reason: Cause I always realize things after the fact.
05-19-2013, 12:55 PM   #18
No AF light with AF-C is logical if you think about it. Unless you like photos of green blobs
Even the K-30 is a bit reluctant to turn on the assist light. I wish there were menu options for adjusting the light level it comes on at. That would be really handy.
05-21-2013, 07:19 AM   #19
pdo
pdo's Avatar
I kept my K30 and sold my original K-5 to ugrade to K5 IIS. After comparing K30 and K5 IIS images. I decided not to upgrade. The K30 images is just awesome even when comparing to cameras like Nikon D4 and Canon 5D III...
05-21-2013, 09:53 AM   #20
Spodeworld's Avatar
So, it sounds like you see a noticeable improvement in sharpness from the original K5 to the K30.
QuoteOriginally posted by pdo Quote
05-26-2013, 07:04 AM   #21
Biro's Avatar
I bought a K-30 body last night now that the price has dropped below $500 (Amazon). The sharper imaging and slightly better auto-focus performance over the K-5 seem to be real. Plus I'm one of those who prefers having the AA-battery power option. Months down the road, when the price of the K-5IIs body comes down further, it may be my K5 that goes on the market, not the K-30.
bit, k-30, k-50, k30, k5, pentax k30, pentax k50
Am I reading this riight ? The Pentax 18-135 WR is sharper than Tamron 17-50 F2.8 ? photoleet Pentax SLR Lens Discussion 21 09-05-2014 08:53 PM
K-01 sharper than k-5? ChatMechant Pentax Mirrorless Cameras 15 05-12-2013 08:23 AM
What's a sharper lens than the 18-55 AND affordable? GibbyTheMole Pentax SLR Lens Discussion 32 10-18-2012 07:56 AM
Is it normal for the CDAF image to be sharper than PDAF? GabrielFFontes Pentax DSLR Discussion 12 10-16-2012 06:03 PM
50mm 1.7 vs 70mm limited for portraits...is one much sharper than the other? shaolin95 Pentax SLR Lens Discussion 13 04-22-2010 05:05 AM
All times are GMT -7. The time now is 01:09 PM. | See also: NikonForums.com, part of our network of photo forums!
