05-18-2013, 08:25 AM   #1
Spodeworld's Avatar
Image sharper than k5?
I saw one poster who did a side by side of the k30 and k5, and the images of the k30 appeared a bit sharper (can't remember if it was only for jpeg, which would be important to know). Also, in Adam's review side by side the k30 seemed to me a bit sharper too. Does anyone who has owned both have the same impression?
Thanks
Still pondering k5 vs k30 (talk about being indecisive!)
05-18-2013, 08:37 AM   #2
Na Horuk's Avatar
I think the cameras are different in other ways, which are more important than apparent sharpness. If you really only care about sharpness, get a K-5IIs and a macro lens
05-18-2013, 09:02 AM   #3
Spodeworld's Avatar
I agree but the k5iis is off the table for a moment (unfortunately).....so I was trying to determine whether these (potential) observations have been seen by those who have experience with both.
05-18-2013, 09:11 AM   #4
I think K5 is a slightly superior Camera, and that the best bet for sharpness is on the lens you are getting.
If you are not pixel peeping difference shouldnt be flagrant.
05-18-2013, 09:40 AM   #5
I believe the K-30 has a weaker AA filter (also the K-01 - they share the internals pretty much). Therefore it actually does produce sharper images.
05-18-2013, 10:32 AM   #6
Spodeworld's Avatar
Is that actually true? If so, that could make a difference.
QuoteOriginally posted by Giklab Quote
05-18-2013, 10:57 AM   #7
Docrwm's Avatar
Are we talking RAW-to-RAW comparison? The JPGs out of the K-30 are sharper than the K-5 at standard settings from what I recall but RAW-to-RAW is a different matter.
05-18-2013, 11:28 AM   #8
ChatMechant's Avatar
I posted a comparison a while back between the k-01 and k-5, and the k-01 was obviously a bit sharper. I think it and the k-30 have the same stuff. I decided to keep the k-5 however because of ruggedness, wr, burst rate, etc. The k-30 might be a nice mix of the two?
05-18-2013, 12:28 PM   #9
Spodeworld's Avatar
We're those DNGs? Or, we're they jpgs?
QuoteOriginally posted by ChatMechant Quote
05-18-2013, 01:18 PM - 1 Like   #10
Heie's Avatar
I have extensive experience with both the K-5, K-30, and now the K-5 IIs, and I must say, the K-30 is inherently significantly sharper than the K-5 Classic.
I was thinking about it quite a bit the other day when I came across Docwrm's K-5IIs impressions thread here. I haven't used the K-5 since November (destroyed it accidentally - my fault, not the camera's), and right now I use the K-30/K-5 IIs, and I must say, I have *not* noticed the same shocking realization between the two. What this means is that I went from the K-5 to the K-30, and then the K-30 to the K-5IIs, and sometimes I have to really search hard to make sure I had the cameras right. The K-30 seems to have a weaker AA filter and honestly be pretty damn close to the performance of the K-5 IIs (yes, IIs). Here's a comparison I did between the K-30 and K-5 IIs. Between the two (K-30/K-5 IIs), if I had to pick one, I would definitely pick the K-5 IIs. Not because of the 14-bit vs 12-bit RAW images, better WR (I would argue they are equal with the K-5 taking the edge because of its far more durable body), but because of some critical features the K-30 is lacking: A top screen (very handy for tripod work), a battery grip option, and above all, a dedicated ISO button. The lack of a dedicated ISO button is my *single* major gripe with the K-30 and it has caused me to miss many shots because of trying to make a quick ISO adjustment (I shoot in manual mode only and part of my shooting style is to make immediate changes to the shutter speed/aperture/ISO when needed), and yet it turns out I am moving the AF points around because they share the same keypad.
If you aren't one to have a super fast need to change parameters (it's just how I've trained myself to shoot) and don't need a battery grip, the K-30 is a fantastic buy and one I recommend 100%. You will *not* be missing out on the "sharpness revolution" as compared to the K-5 IIs.
Hope this helps
-Heie
05-18-2013, 01:58 PM   #11
I seem to remember having the indecisive ISO button issue same as you when I first had my K-30 but never see it now. Perhaps it was a thing of the past after after I set the RAW/Fx button to AF point select.
Oh, and yes I agree the K-30 is very sharp with the right optics, especially with landscapes for some reason - probably the bright light as much as anything.
05-18-2013, 02:08 PM   #12
Spodeworld's Avatar
@Heie - really interesting comparison of images. Looks like the SOOCs are better from the K5iis but after processing the difference narrows considerably. I do think the color rendition looks a bit better on the k5 IIs, but I digress.
Do you find a marked AF improvement on the k30 vs the k5 classic? How about in more challenging light?
Thanks
05-19-2013, 01:13 AM - 1 Like   #13
Heie's Avatar
QuoteOriginally posted by SteveB Quote
I seem to remember having the indecisive ISO button issue same as you when I first had my K-30 but never see it now. Perhaps it was a thing of the past after after I set the RAW/Fx button to AF point select. Oh, and yes I agree the K-30 is very sharp with the right optics, especially with landscapes for some reason - probably the bright light as much as anything.
Hmm....I will have to experiment with that. Thanks! And yes, the K-30 is a phenomenal camera. I really wish Pentax would have gone all in with investing in the marketing and product placement of it at Targets, Walmarts, Best Buys, etc. It is so far and beyond a superior camera compared to anything the competition has in that price range, especially last summer.
QuoteOriginally posted by Spodeworld Quote
@Heie - really interesting comparison of images. Looks like the SOOCs are better from the K5iis but after processing the difference narrows considerably. I do think the color rendition looks a bit better on the k5 IIs, but I digress. Do you find a marked AF improvement on the k30 vs the k5 classic? How about in more challenging light? Thanks
Glad it helped Yes, I agree with the gap closing with processing, which is why I did it. I would get irritated at the absolute stupidity of seeing countless threads discussing how the K-5 II processed files were just as good as the K-5 IIs unprocessed files. How that is relevant/applicable/practical/useful to anything is simply beyond my logical abilities. But I digress...
I haven't used the K-5 in over 6 months, but I do remember that my first impression of the K-30 when I took it out of the box (in Afghanistan ) was that the AF was much more decisive. I don't have any experience with continuous tracking AF since that isn't my shooting style/needs, however just standard single point AF? The K-30 is much better. I also never had an issue with FF/BF with the K-30 (and subsequently the K-5IIs either, thankfully) and I spent quite a few frustrating days tinkering with it on the K-5. Not a huge deal on 1-2 lenses, but when you have over 5 and most are zooms, it takes its toll.
Hope that answers your question
-Heie
05-19-2013, 08:49 AM   #14
Spodeworld's Avatar
@heie - one last thing. Do you notice better AF in low light. The k20d just doesn't cut it, and the k01 isn't dramatically better. I know that the k5ii/s is the way to go for low light focusing, but just wondering how you find the K30 in low light vis-a-vis the K5 classic. Thanks again. I was considering a used k5, but now am leaning towards a k30.
05-19-2013, 09:23 AM   #15
DNG's
sounds like a good plan.
bit, k-30, k-50, k30, k5, pentax k30, pentax k50
Am I reading this riight ? The Pentax 18-135 WR is sharper than Tamron 17-50 F2.8 ? photoleet Pentax SLR Lens Discussion 21 09-05-2014 08:53 PM
K-01 sharper than k-5? ChatMechant Pentax Mirrorless Cameras 15 05-12-2013 08:23 AM
What's a sharper lens than the 18-55 AND affordable? GibbyTheMole Pentax SLR Lens Discussion 32 10-18-2012 07:56 AM
Is it normal for the CDAF image to be sharper than PDAF? GabrielFFontes Pentax DSLR Discussion 12 10-16-2012 06:03 PM
50mm 1.7 vs 70mm limited for portraits...is one much sharper than the other? shaolin95 Pentax SLR Lens Discussion 13 04-22-2010 05:05 AM
All times are GMT -7. The time now is 03:18 AM. | See also: NikonForums.com, part of our network of photo forums!
