05-20-2013, 07:25 AM   #16
Am I missing something? The bad aperture mechanism (in lens) should only introduce the evenly underexposed pictures. Here I see that something is blocking the sensor. Something like slow mirror.
Cheers
05-20-2013, 12:12 PM   #17
Dr.Pentaxian's Avatar
Thanks for the feedback. I tried a few things based on what you suggested. I completely charged the original battery and mounted the DA-L 18-55mm AL wide open (f3.5). The setting was P mode (Tv hyper). Same thing happened again al 1/5000 and 1/6000 (see image). I'm guessing it's a mirror problem. Since we don't have Pentax Service around here I'll just will have to avoid higher speeds...
05-21-2013, 01:39 PM   #18
Otis Memorial Pentaxian
Oh well, the OP apparently has disappeared...I guess we will never know!!!
05-21-2013, 09:51 PM   #19
altopiet's Avatar
Steve, he hasn't been gone that long... some of us do have to work for a living
About Dr.Pentaxian
Country
Chile
Pentax Cameras
K-30
Photographic Equipment
SMC Pentax-DA L 18-55mm F3.5-5.6 AL
Occupation
M.D.
05-24-2013, 07:58 AM   #20
QuoteOriginally posted by pavpen Quote
Cheers
Remember that at speeds faster than the X-sync speed, the shutter operates as a moving slit. If the light intensity changes as the slit moves, you will get a gradient effect.
As for the mirror...it has been my understanding that most shutter systems are integrated into the mirror box such that the shutter travel does not start until after the mirror is confirmed in the up position. Conversely, the mirror does not fall until after the following curtain finishes its travel. At least that is how they used to make them. Things may be different now with the requirement for high FPS drive rates.
A good check would be to use the 2s delay or self-timer mechanism to take the mirror out of the loop.
05-24-2013, 08:42 AM   #21
If it helps, I just tried my K-30 with a few old lenses, K55/1.8, A50/1.7, M135/3.5, Vivitar 28/2.8 in M, Av modes at f8 and wide open and couldn't see any issues at all at 1/6000sec.
05-24-2013, 10:38 AM   #22
Thanks Steve, I'll try it and post the results.
05-24-2013, 11:07 AM   #23
I followed Steve's suggestion and tried it with the 2s delay. Mode M, M-50mm lens wide open (f1.7) at 1/5000s. This is what I got...
PENTAX K-30  Photo
05-24-2013, 03:11 PM   #24
QuoteOriginally posted by Dr.Pentaxian Quote
Well, there you go. Wide open, M-mode, mirror up, nothing left to blame but the shutter.
Hello, Pentax? We have a problem...
It is still on warranty, I hope
05-24-2013, 04:20 PM   #25
Sagitta's Avatar
Did you try a different battery?
My same issue cleared up when I tossed the lousy batteries I was using and reverted to the kit battery and better quality AA's.
10-06-2017, 04:58 PM   #26
Anyone find a solution?
Hey, did anyone ever find a solution to this, I currently have a Pentax K-x that is exhibiting the same problem. Seems fine at 1/4000 but once you switch to 1/5000 you get about a quarter of the top screen blacked out. When switching to the highest speed of 1/6000, you get about 1/3-/12 of the screen blacked out. Not the hugest problem in the world as those shutter speeds rarely are a necessity but I feel more comfortable knowing all the gremlins that my camera currently has. If anyone ever figured this out or has any ideas, feel free to give me an update. Thanks.
k-30, k-50, pentax k30, pentax k50, shutter
Why is my shutter speed stuck at 1/60? Culture Troubleshooting and Beginner Help 28 06-07-2012 08:32 AM
Pentax k5 with 50mm 1:1.7 and shutter speed smack1019 Pentax K-5 10 03-04-2012 03:52 PM
For Sale - Sold: K20D - Low Shutter Count < 6000 (Worldwide) woof Sold Items 10 03-07-2011 03:10 PM
Pentax KX Shutter starting to stuck at slow shutter speed. Spirit722 Pentax Film SLR Discussion 7 03-03-2011 09:49 PM
K-x & AF360 flash - shutter speed 1/15 or 1/30... always flippedgazelle Flashes, Lighting, and Studio 3 04-02-2010 12:42 AM
All times are GMT -7. The time now is 04:39 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
