02-15-2019, 08:54 PM   #16
i may have jumped the gun disliking it, the shake reduction seems to do it's job after i got used to it.
02-16-2019, 10:48 AM - 1 Like   #17
retired sw engineer
reh321's Avatar
QuoteOriginally posted by john.smuda.3 Quote
Yes, when I had a Canon Rebel and a small-sensor Pentax Q-7, I used the Q-7 for indoors photos because it allowed me to take good photos despite needing longer exposures. Recently I took this photo with by light from a table lamp only, holding the Q-7 one-handed at an awkward angle, of my buddy as she lay next to me - shutter speed is 1/4 second.
02-16-2019, 01:23 PM - 1 Like   #18
Otis Memorial Pentaxian
photolady95's Avatar
SR isn't automatically disabled if your camera is on a tripod. You have to disable it yourself.
02-24-2019, 12:22 PM   #19
ah ha! I got a legitimate work around! 2 second delay after shutter button....
ah ha! I got a legitimate work around! 2 second delay after shutter button. is pressed it takes a picture with shake reduction on!
use 'interval shooting' mode. set it to 2 exposures total, two seconds apart.
so, here is what happens,
1. press the shutter button.
2. takes a picture.
3. hold camera steady with your hand
4. two seconds later a picture is taken with shake reduction on automatically
5. delete first picture.
downside is it takes twice as many pictures, but i got what was most important to me. that is: after I press the shutter, the camera gives me two seconds to steady my hands, and then automatically takes a picture.
to me, the 'shutter bounce' that happens when you take a picture is very severe. no matter how careful i am. I dunno, maybe it's just me.
I just always thought the whole purpose of the two second delay was to eliminate shutter bounce. I am still amazed Pentax turns off all shake reduction with the two second timer because they assume you are using a tripod. why have any delay on a tripod at all?
02-24-2019, 12:54 PM - 1 Like   #20
clackers's Avatar
Because on a tripod you can still get both shutter and mirror shock.
An answer to shutter shock is an electronic shutter, BTW, as long as artificial lights conditions are favourable and subjects aren't moving.
02-24-2019, 01:42 PM - 1 Like   #21
It is a silly idea going back at least 60 years where it was assumed that tripods might not be particularly stable and might actually harbor resonance traceable to SLR mirror slap as well as shutter press. Some makers* offered mirror-up on shutter press with the self timer,** hence a similar silly feature on today's cameras.
* My Ricoh Singlex TLS, Ricoh XR-2s, Exakta VX IIa, and Exakta VX 1000 are all that way.
** The idea being that the timer would allow vibrations to dissipate prior to opening the shutter.
01-30-2021, 01:48 PM   #22
I have a similar problem.
Sr worked fine. I tried I think exposure bracketing, and since then, I can't turn SR back on again. Tried setting everything, still can't turn on again SR.
Firmware version is 1.06.
I am grateful for any ideas.
01-30-2021, 02:20 PM   #23
MarkJerling's Avatar
QuoteOriginally posted by Juhos Péter Quote
Try the camera in Green mode and check if SR works in that mode? If it does, then you've done something to the settings.
02-02-2021, 04:19 AM   #24
Unfortunately it doesn't work in Green mode either, but works in video mode... (????)
02-02-2021, 03:56 PM   #25
Have you tried a complete reset?
02-02-2021, 10:48 PM   #26
Multiple times, although that's not a complete reset. I should make a real factory reset I guess, but I'm not shure if there is one.
02-03-2021, 02:45 AM   #27
Try the setup menu (wrench icon), the reset option should be on the last or second to last page.
k-30, k-50, pentax k30, pentax k50, reduction, shake, shake reduction, sr
shake reduction can't turn on ? davidsyd Pentax K-30 & K-50 3 12-24-2012 07:32 AM
K5 won't turn on! ozlizard Pentax K-5 & K-5 II 10 03-14-2012 02:35 PM
Turn shake reduction off on monopod? lester11 Troubleshooting and Beginner Help 7 06-27-2011 02:15 PM
Shake Reduction won't turn on.. ChallengedOne Troubleshooting and Beginner Help 12 04-11-2011 01:18 PM
Can't turn shake reduction back on - K5 vrphoto Troubleshooting and Beginner Help 5 04-10-2011 09:22 PM
All times are GMT -7. The time now is 05:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
