Hello!
I admit that I am not a technical guy, I thought maybe I am doing something wrong, maybe miss something, but well, I take my sis DSLR and when I adjust built in flash power, I actually see the difference between -2 and + 2 values for the pop up flash. My sis has Olympus DSLR, then I tried on my friend's Canon 60D, the difference between power levels are also visible. However when it comes to my K-30, regardless of what power level I have for it, it just shoots flash at max value. There is no difference ranging from -2 to +2. is that an issue with my K-30 or is this normal behavior and I am supposed to use special technique because on Pentax pop up flashes always shoot at all they have got?
Sometimes I need to use the pop up flash and would like it to not make my pictures be burnt white. On some occasions I want to do some slight fill light thingy but even bounced flash light from the sealing or somewhere else is just too active, not to mention that it drains the battery really much.
I am very grateful for every advice.
