Originally posted by Paleo Pete I don't understand why it's there at all. No need. Make it aperture ring capable to begin with, forget about the setting and you're good to go. Auto lenses still work either way so why is it there at all???
I think it is done to reduce technical support calls and camera returns - basically protecting users from themselves. If you are using a lens in something other than an 'A' setting, there are other things the user has to do to get a correct exposure. If the camera won't release the shutter, you can't have a poor exposure, correct?
Personally, I short the 'A' pin on my camera and make my camera think every lens is in the 'A' position. If I am using a lens without 'A' capability, I am then responsible for any exposure adjustments between the body settings and lens settings. If I am, for example, using a M-series lens, I set both body and lens to the same aperture value, do a test shot, look at the histogram and add any necessary exposure compensation. If you use a non-A lens often enough, you don't even need the test shot. This also gives you access to automated exposure and flash functions that are otherwise not available.
Pentax isn't unique in this 'protect users from themselves' philosophy. Microsoft is notorious for the same practice.
