07-09-2013, 04:28 PM   #1
"Dust Alert"
Am I missing something or did Pentax get RID of the "Dust Alert" function that was handy on my K-x for pinpointing where the dust was on the sensor before applying the blower?
07-09-2013, 06:19 PM   #2
vanyagor's Avatar
Yes, this feature is gone in K-30. However there is an easy test which gives you a good idea where the dust is (see in the comments in the 2 threads below):
https://www.pentaxforums.com/forums/pentax-k-30/195666-dust-alert.html
https://www.pentaxforums.com/forums/pentax-k-30/215388-dust-alert.html
07-09-2013, 08:01 PM   #3
ramseybuckeye's Avatar
QuoteOriginally posted by kodai84 Quote
Unfortunately it is no more. That's the only thing the K20D had that I miss on the K-30, and I guess I don't miss it that much. If it's not a bright sky to walk outside and shoot, I take a photo of a white screen on the computer (like a blank word processing document) and then look at that. Just remember that the screen is upside down and reversed from looking at the sensor.
07-10-2013, 10:47 AM - 2 Likes   #4
QuoteOriginally posted by ramseybuckeye Quote
Closing down the aperture as far as it goes, and using as long a focal length as possible will make the dust more visible.
Another better way I found to show even the smallest specs of dust is to remove the lens and take a photo from some distance of a very bright LED torch with its focusing lens removed. The idea is to have a small point source. You need to this in a dimly lit or darkened room. This casts sharp shadows of the dust onto the sensor. Even better if you shoot a number of pictures with the camera pointing in different angles, slighlty offset from facing diectly at the torch, say up to some 30 degrees or so. This apart from dust will also reveal oily smudges, which will appear at different angles of incidence.
I suppose you can do the same with the sun, though for some reason I never tried it. That is remove the lens and point the camera towards the sun and shoot phots, again at various angles. This should pose no risk of burning out anything since there is no lens to concentrate the sun's rays.
For all this it is best to use low ISO and choose the right shutter speed to get a bright grey, but not entirely white image.
07-10-2013, 01:19 PM   #5
QuoteOriginally posted by lister6520 Quote
Good points!
k-30, k-50, pentax k30, pentax k50
Optical differences between Pentax "K", "M", and "A" lenses 6BQ5 Pentax SLR Lens Discussion 31 01-10-2014 01:02 PM
Don't say Pentax "Q" in French ... "Q" = "cul" = "A--" Jean Poitiers Pentax Q 52 11-10-2013 06:25 AM
I need "dust spot" ID please! jpzk Pentax K-5 11 04-02-2013 06:42 PM
"Christians for a Moral America" plan boycott of "The Hobbit" MRRiley General Talk 47 01-23-2012 01:48 AM
K-x "aperture priority" records as "automatic" in meta data charlestm Pentax DSLR Discussion 3 12-05-2011 12:12 PM
All times are GMT -7. The time now is 06:00 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
