Originally posted by crewl1 If the K-30 is like the K-5 the mode wheel set to M should allow the front wheel to change the shutter speed,
Well, it doesn't. I've tried setting the drive mode, but not knowing which I should set it for, I'm not sure which I should chose. I went to the second page of options and found "M to something to something" and set it there, but it made no difference when using the wheel/s.
Na Horuk, I should have mentioned, the lens is on the A setting and the menu option for allowing aperture usage is also set. I did have the K-x for a few years and knew to set those two thiings. Btw, I'm not new to photography, just the K30. I have the .pdf manual, have had it since the K30 was introduced because I wanted to read it to see if it was the camera for me.
Auto ISO was one of the first things I changed.
Ok, I just did a reset and now the rear wheel allows me to change the shutter speed. Must have been some setting the previous owner had set.
Na Horuk, I know how to use Manual lenses on these digital cameras, I've got four M lenses.
