07-13-2013, 10:29 AM   #1
Danas_Anis's Avatar
K30 mirror up, what is there, should it be like this?
Hello!
I am a bit paranoid since I did not memorize whether the thingy in the picture is supposed to be like this or do I have a problem there?
I was using a manual lens and all of the sudden K30 began to do some mirror flipping when in Live view, it never used to do this,
sorry for the low quality picture, it was taken with a phone,
Thanks for your time!
LG-P760  Photo
07-13-2013, 10:44 AM   #2
Sagitta's Avatar
I just fired a few test shots off with my K-30, and the wire you're seeing DOES appear at the height of the shot (ie, when the mirror is up), but of course it then drops right back into place again. You're basically looking at the halfway point of the process of a shot being taken in your photo there.
Before panic sets in, do yourself a favor and insert a set of brand new AA's (or if you don't have the adapter, a fully charged LiON). This could simply be a case of your battery(ies) having gone PFFT on you and the camera dying from that. Weak batteries can cause that mirrior slap, I have had it happen myself when using faulty ones.
07-13-2013, 11:48 AM   #3
Danas_Anis's Avatar
Sagitta,
thank you very much for your reply!
phew, I thought its bad and is a part of construction that got loose, but if you also are seeing this, then I am now calm
I am actually in video mode with the lens off that is why I can see it, in video mode mirror is always up.
I just wanted to see whether my manual lens is making something to the cam so it makes the mirror slaps, and noticed that wire thing,
you saved my day! So it appears to be normal condition of k30.
Thank you for your reply!
07-13-2013, 02:46 PM   #4
You'll get a lot of dust on the sensor doing this.
k-30, k-50, k30, mirror, pentax k30, pentax k50, picture
Mirror Flop! Just What Exactly Is It???? BirdDude007 Pentax K-5 6 06-09-2012 08:26 AM
Back up body, what lens should I leave on it? suliabryon Pentax DSLR Discussion 15 12-08-2011 11:59 PM
Is this as sharp as it should be? Todd Adamson Pentax SLR Lens Discussion 29 11-03-2010 01:34 AM
Test with the 55-300mm. Is this as it should be? Kevin1961 Pentax SLR Lens Discussion 39 05-12-2009 02:18 AM
When there is a K?D what will it be like? benjikan Pentax DSLR Discussion 114 01-24-2008 07:48 AM
All times are GMT -7. The time now is 01:21 AM. | See also: NikonForums.com, part of our network of photo forums!
