Greatly appreciated all responses. Special thanks to MATT he left responses in flicker.
The loose battery holder could be cause of Camera Freeze.
In both rides (safari, stunt show) was stopped to see the show. From EXIF data I see I set it APERTURE PRIORITY and was 1/50. I should have set it 1/100 or more.
I think in Camera body image stabilization is less effective.
I figured out Windows Picture shows Metering Mode MULTI-SEGMENT as Pattern.
But I could not resolve "Color Representation: uncalibrated".
Here is the EXIF data. Also picture is uploaded in the flicker.
_IGP0423 | Flickr - Photo Sharing!
Exif data
Camera Pentax K-30
Exposure 0.003 sec (1/320)
Aperture f/5.6
Focal Length 36 mm
ISO Speed 100
Exposure Bias 0 EV
Flash Off, Did not fire
Orientation Horizontal (normal)
X-Resolution 300 dpi
Y-Resolution 300 dpi
Software K-30 Ver 1.04
Date and Time (Modified) 2013:06:15 18:27:15
White Point 0.313 0.329
Primary Chromaticities 0.64 0.33 0.21 0.71 0.15 0.06
YCb Cr Coefficients 0.299 0.587 0.114
YCbCr Positioning Co-sited
Exposure Program Aperture-priority AE
Date and Time (Original) 2013:06:15 18:27:15
Date and Time (Digitized) 2013:06:15 18:27:15
Metering Mode Center-weighted average
Color Space Uncalibrated
Sensing Method One-chip color area
Custom Rendered Normal
Exposure Mode Auto
White Balance Auto
Focal Length (35mm format) 54 mm
Scene Capture Type Standard
Contrast Normal
Saturation Normal
Sharpness Normal
Subject Distance Range Close
Gamma 2.2
Print IMVersion 0300
Compression JPEG (old-style)
Thank you,
Sandeep Singh
