Originally posted by 6BQ5 Am I the only one annoyed that the focal length can only be selected in pre-chosen steps vs. 1mm increments? What's the limitation?
Mmh, maybe there could be some way to add more accurate number choices (like choosing each of the three dials separately), or to add shortcuts for a couple of the ones you use the most. But if its just a simple slider, 1mm would be too small. Going from 14mm to 300mm would take very long.
Btw, when you cant get right on it, I think its better to have a slightly wider input focal length than a slightly bigger one. Its better if the SR is less effective than overcompensating
