09-05-2013, 01:28 AM   #16
Aux
Khm, I read about green button and metering with manual lenses a lot and don't understand what you all are talking about. I just went to settings, turned apperture one and shoot in Av mode without any problems and without pressing anything but shutter button. Do you guys talk about manual lenses with autoaperture control? Because I have only full manuals and control apperture directly on the lens.
09-05-2013, 04:00 AM   #17
QuoteOriginally posted by Aux Quote
With a K mount lens or an M42 lens?
With an M42 lens it will work OK in Av mode, since the camera has no control over the aperture and it stays wherever you set it all the time. You are effectively always doing stop down metering. There are inaccuracies due to the non-linear nature of the default focusing screen, but it will work well enough with some exposure compensation added as you stop down.
With a K mount lens without the A contacts it will only work wide open, it will ignore whatever the aperture ring is set to. If you take a shot wide open in Av mode and it gives you a shutter speed of 1/100, put the aperture ring at f8 and the camera will still shoot at 1/100, but the image will not be underexposed because the lens never actually went to f8.
button, figure, k-30, k-50, lens, lenses, pentax k30, pentax k50, series, stop
No stop down metering with pentax-m lenses (K-x) Aeldrhamir Pentax DSLR Discussion 10 01-23-2013 09:49 PM
6x7 Lenses on 645n & Stop-down Metering Trouble Dubesor Pentax Medium Format 4 02-04-2012 07:03 PM
Stop down metering on a PZ-1p blackcloudbrew Pentax Film SLR Discussion 2 11-03-2011 02:01 PM
Stop-down metering not working with extension tube on K-5 (works on K10d) Beau Troubleshooting and Beginner Help 3 09-13-2011 04:37 AM
Stop Down metering with K-5 jva59 Pentax K-5 8 03-29-2011 06:43 AM
All times are GMT -7. The time now is 11:10 AM. | See also: NikonForums.com, part of our network of photo forums!
