Originally posted by jaikumarr18 Am planning to take Canon 700D to the store today and would initiate the exchange. Hopefully they should agree to swap back to Pentax K30 as per the policy. Also one issue I failed to mention that I found with Pentax K30 is the shadow cast when using flash. A semi circle found on the bottom of the picture. I did not find that issue with Canon 700D with the same object, distance and light condition. Is it due to 17-70mm lens in Pentax K30 or any settings that I failed to configure on Pentax?
That Sigma 17-70 got a huge hood, or even without the hood the front element is rather big, so it will cast semi circle shadow when you use the build in flash(if you have read the user manual there is a chapter on it), that's not much you can do about that in either Canon or Pentax system, if you mount the same Sigma 17-70 lens(you can also get it in Canon mount) on 700D, I bet you any money that the build in flash will cast a shadow too...That's the price you pay for using a long/large lens, usual work around is to get an external flash
Take the hood off and use the build in flash, see it it can work on the wide end(17mm-20mm), I remember using the kit DA18-55WR with the hood which is tiny compare to the Sigma 17-70 @18mm end and it still cast a shadow...I know it is annoying, but it's the same across the system Pentax/Canon/Nikon
