Your post prompted me to drag out a micrometer and do some measuring when I should be reading a good novel. Though at times it was hard to measure I think I got some variations that indicate a different standard or poor quality control by one or more of these manufacturers.
Front to back depth: K-30 17.46 mm, G9 18.57 mm, Flash 20.52 mm, this might not be a problem.
Left to right width: K-30 18.74 mm, G9 18.84 mm, Flash 18.66 mm, this is identical given my degree of error.
Depth of groove for mount: K-30 1.76 mm, G9 2.5. mm, Flash (thickness of plate) 18.66 mm, even given my degree of error this is where the big difference is. BTW, the measurement of the flash plate thickness was after I had taken it down a little with a nail file in an attempt to make it useable. I searched vainly for the standard measurements, but the only thing that looked promising was a PDF of the standard you had to pay for, I wasn't about to do that.
As to features, for now a manual setting flash will have to be sufficient. The big thing I'm looking for is too be able to bounce the flash.
Originally posted by elliott Pretty much every hotshoe is the same size, it is even defined in ISO 518:2006. If the flash fit on the G9, it will fit on the K-30. Sony is the only one with a non-standard hotshoe.
What kind of features are you looking for in a flash? Is P-TTL metering a requirement? That will be tough under $100.
