09-25-2013, 06:14 AM   #1
K30 custom menu
I've searched the K30 manual for references to setting a "custom" menu and can't find any. Does anyone know of a way to set a custom menu up? I would like to be able to have a short menu with my most used functions on it. Thanks for any input, either way.
09-25-2013, 06:30 AM   #2
6BQ5's Avatar
You may be thinking of saving your current settings to one of the user modes (U1 and U2). For example, I have my U1 set for HDR shots in JPG format.
09-25-2013, 06:34 AM   #3
HockeyDad's Avatar
QuoteOriginally posted by manmarco Quote
To the best of my knowledge, the K30 has no such feature. However, I'd use the heck out of it if it existed. Like being able to customize a couple of the spots on the quick menu that pops up when you press the info button would be awesome because there's a couple of things on that menu that I never ever use and there's a couple of features buried in the regular menus that I use all the time.
09-25-2013, 07:11 AM   #4
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
As Boris pointed out you can use U1 and U2 for saving your settings. Check your manual page 168 and it will give you a list of what can settings you can save. Check through page 170 for other options in these user settings mode.
09-25-2013, 08:31 AM   #5
HockeyDad's Avatar
QuoteOriginally posted by 6BQ5 Quote
QuoteOriginally posted by photolady95 Quote
I took the OP to mean creating a custom "menu" not a custom "mode". In other words, if you find yourself using a setup you've stored in U1 but need to adjust WB for every location, the WB reverts back to the one stored in U1 each time you power the camera off and back on. Solution, re-save U1 at each location which is buried on the bottom of the 4th page of the menu. Perhaps you like to toggle focus peaking off and on, or the electronic level... whatever, it would be neat if you could build 1 menu page with your frequently used items in it, or edit the quickmenu to maybe replace things like JPEG Quality that you rarely adjust with things you use. Each photographer is unique of course and IMHO Pentax does a GREAT job with the quickmenu that's accessible with the info button. But I'm sure we could all find a couple items on that menu we'd like to swap out for things we frequently dig through the menus for.
I'm relatively new to photography so I'm sure that sort of "My Menu" functionality is reserved for high-end cameras because to my knowledge, there's no way to do that on the K-30.
09-25-2013, 09:26 AM   #6
As Boris said, and I'm sure he thought she meant the same as I did because of the sentence above, that OP wants a way to save/make a custom menu that would save OP's setting used most. That is what the U1, and U2 are for.
09-25-2013, 06:44 PM   #7
Thanks
Thanks to all who took the time to answer.
I was intrigued by a remark by Jeff Cable, on one of B & H's youtube videos, that he uses custom menus to quickly access features for settings. He was shooting with a Canon, high-end I'm sure and i wanted to do the same.
BTW, the K30 is my second Pentax DSLR and I love it. I started with used Pentax equipment 25 years ago. I put them aside for several years and in '07 bought a D100 Super, which my grandson is using for a 10th grade photography class.
Again, much thanks to all.
09-25-2013, 07:41 PM   #8
You're welcome. But I have a question. Did any of the answers you received help at all?
09-26-2013, 04:01 AM   #9
I'm sorry, I should have stated that the messages did help. Especially regarding "User 1" and "User 2". I will set-up those options and try them.
BTW, although I've not posted much here I've really enjoyed reading the posts and have learned a lot from them. I like the way that the forums are setup and the feeling of being in a caring, supportive community.
09-26-2013, 04:25 AM   #10
HockeyDad's Avatar
Yikes, looks like I was way off base. Thankfully there were more experienced minds here to get you pointed in the right direction. The user modes, U1 and U2 are fantastic for storing your most frequently used setups. In fact, those were a HUGE motivating factor in my upgrade decision when I went from K-r to K-30.
09-26-2013, 07:20 AM   #11
I'm glad to hear you like PF, they have been very helpful to me also and always in a friendly manner.
09-26-2013, 07:55 AM   #12
6BQ5's Avatar
Yes, this forum is pretty civil and well run. People aren't overly polarized. All bets are off in the Full Frame threads though.
custom, k-30, k-50, k30, menu, pentax k30, pentax k50
Menu Settings - K30 Mlcinema Pentax DSLR Discussion 2 01-17-2013 07:18 AM
Does custom menu item #21 work correctly? Full_Stop Pentax K-5 18 07-06-2012 04:08 AM
finding custom menu ? Andrew Crouch Pentax K-5 5 12-05-2011 11:37 PM
Pentax K20D Custom Menu 35 Reportage Pentax DSLR Discussion 9 02-09-2010 05:25 AM
GX10 and custom menu question (EV) rqy99g Pentax DSLR Discussion 2 02-13-2009 09:54 AM
All times are GMT -7. The time now is 07:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
