10-05-2013, 06:33 PM   #1
B exposure for K-30, how long would you....
How long would you open the B exposure of your K-30 at ISO 100 w/o obvious noise? Any recomendations
10-05-2013, 06:53 PM   #2
QuoteOriginally posted by wed7 Quote
With DFS on you can go for however long you'd like pretty much. Even with it off, I've taken exposures lasting many minutes w/o issues.
10-05-2013, 11:27 PM   #3
what is DFS? dont see it in the manual?
10-05-2013, 11:32 PM   #4
Dark Frame Substraction (or something along those lines) - the camera takes another shot with the shutter closed, so as to detect noise and remove it in the final image.
10-06-2013, 12:31 AM   #5
is this done automatically in bulb mode?
i havent ever tried to B mode
10-06-2013, 01:04 AM   #6
No idea, but there is a setting somewhere in the menu about it.
Edit: The settings are Auto, On or Off. But you'll have to test what it does yourself since it's pretty bright over here.
10-06-2013, 01:14 AM   #7
is this in the k-30? i dont see that in my menu ?
10-06-2013, 01:36 AM   #8
Replied to PM
10-06-2013, 04:44 AM   #9
QuoteOriginally posted by jrcastillo Quote
Menu group 3, second line - Slow shutter speed NR
It seems to work even on B but I don't know if there is any time limit on the dark frame. I manually shot a 15 second exposure in B and it shot the dark frame lasting about the same time. May or may not work for more than 30 seconds.
10-06-2013, 08:04 AM   #10
The reason why I as about this is that I want to try light painting and would not want to get noisy images if use prolonged exposure.
10-06-2013, 11:04 AM   #11
i have done several minute exposures on my K-30 without any noticeable noise issues...up to 312 seconds so far
10-06-2013, 11:08 AM   #12
carrrlangas's Avatar
Ive done 600seconds exposures with DFS on and it works really well. Ive noticed its better to use ISO400 or 800 instead of ISO100 as long exposure noise gets higher than high iso noise.
As for light painting, I dont think youll need B mode. 15 or 20 sec exposure works ok
10-06-2013, 07:38 PM   #13
Ok i'll try using the lowest possible ISO up to 20 sec exposure. I'll update this thread eventually, thanks
exposure, k-30, k-50, pentax k30, pentax k50
K-30 with serious front focus: what would you do? causey Pentax K-30 & K-50 10 04-27-2014 11:01 PM
How would you rate the video from the Pentax K-30? memo90061 Pentax K-30 & K-50 23 11-05-2012 11:42 PM
Camera would not revive after long shutter exposure dmbaile2 Pentax K-r 4 05-17-2012 07:09 PM
How would you spend $10,000 on K-mount glass? spade111 Pentax SLR Lens Discussion 52 03-01-2012 05:55 AM
Long exposure / provia 200 : how to know the good exposure compensation ? aurele Pentax Film SLR Discussion 3 02-18-2012 06:58 PM
All times are GMT -7. The time now is 11:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
