10-12-2013, 10:44 PM   #1
Need viewfinder advice
Taking pictures in the daylight today, with 16-45mm lens, and using Spot exposure and focus.
1. Noticed that, if I did an AE/L exposure lock, the little asterisk would come on in the optical viewfinder... but the viewfinder bottom-line display would go black after about 15 seconds... then, when I pressed the shutter button halfway again to re-activate the display line, the exposure lock asterisk was gone. Is there a way to keep the exposure locked and displayed until a second press of the AE/L button?
2. Using live view on the back screen, noticed that the K-30 shows bright red areas where you are overexposing the image. Is there a way to turn off this feature, so I can just see the image without the red overexposure warning areas?
Thanks in advance for any tips... I've looked through the manual about all this, and didn't find anything...
10-12-2013, 11:13 PM   #2
On all my Pentax cams the AE/L stays locked until I take a shot no matter if the OVF display goes blank
Bright/Dark view is under 'Instant Review' and under 'Live View' on the K-7 and under Live View on the K-01.
I assume it would be similar on the K-30
Edit: Page 176 and page 212 of the K-03 manual, Jon.
Edit#2: On the K-01 and the Q the AE/L remains on even after a shot, only disappears when I access another option
10-12-2013, 11:55 PM   #3
Fogel70's Avatar
QuoteOriginally posted by jon404 Quote
No, but you can use manual mode instead and use green button to set exposure. Then the exposure will be locked until you press green button again.
This is my preferred mode using spot metering, and I have set the green button in manual mode to be TV-shift.
AE-lock will only be activated as long as exposure meter is active. But you can choose to have exposure meter active for longer time. (up to 30s).
10-12-2013, 11:59 PM   #4
Thanks Steve -- the one for 'Instant Review' -- page 212 -- worked... I unchecked it and the red/yellow areas are gone.
But I'm still puzzled by the optical vewfinder display line turning off and erasing my AE/L exposure lock!
EDIT -- scratch that last -- thanks, Fogel70! Found the 30-sec optical viewfinder display setting, on C Custom menu page 1, choice 4. Thirty seconds should work just fine.
10-13-2013, 12:31 AM   #5
Fogel70's Avatar
Checked to K-30 manual, and it seems like AE-L will be active for twice the exposure metering operating time on K-30. So with 30s operating time the AE-L should be on for a full minute.
10-13-2013, 02:33 AM   #6
QuoteOriginally posted by Fogel70 Quote
Thanks again -- today, I was waiting for a train to come by, pre-focused and with a suitable exposure lock. Thought the K-30 would just hold it until I pushed the button a second time, like the K-01. Next time, will work with the one-minute limit. Or maybe resuscitate the K-01 for this kind of thing!
10-13-2013, 02:43 AM   #7
Fogel70's Avatar
You can also use LV on K-30 to get it to work the same way as K-01.
asterisk, button, display, exposure, image, k-30, k-50, pentax k30, pentax k50, viewfinder
Need Repair Advice MaKettle Troubleshooting and Beginner Help 3 09-09-2013 04:42 AM
Cracked viewfinder - any advice? fstdslrkx Troubleshooting and Beginner Help 21 08-03-2012 10:26 AM
Newbie need advice hamrio Pentax K-5 13 07-27-2012 10:31 AM
Need Lens Advice john mood Pentax SLR Lens Discussion 15 01-23-2012 09:43 AM
Sold lens ... now need advice on what I need jpzk Pentax SLR Lens Discussion 35 11-29-2009 10:32 AM
All times are GMT -7. The time now is 05:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
