10-16-2013, 07:40 PM   #1
Firmware 1.05 Issue for K30
After upgrade, the horizontal and vertical level indicator stopped functioning. Is this a known problem with this firmware version ?
Finally I just downgrade again to 1.04 and everything works fine
10-16-2013, 07:42 PM   #2
This isn't a know issue as far as I'm aware. Are you sure the setting that enables the electronic level wasn't just reset?
10-16-2013, 08:06 PM   #3
clackers's Avatar
Fine on mine.
10-16-2013, 08:22 PM   #4
QuoteOriginally posted by jleonardi Quote
How did you downgrade the firmware?
10-17-2013, 05:10 PM   #5
QuoteOriginally posted by IchabodCrane Quote
Indeed. Is that even possible?
10-18-2013, 06:15 AM   #6
treebeard's Avatar
QuoteOriginally posted by OldNoob Quote
I have been on 1.05 since it came out and I have not had any issues with it.
10-21-2013, 06:39 PM   #7
Thanks for the reply
Thanks all for the reply.
To answer the question about downgrade, the step is the same like upgrade.
10-23-2013, 11:21 AM   #8
ScooterMaxi Jim's Avatar
I'd try the install a second time, making sure that the card you're using is freshly formatted in camera. It seems no one else here has reported any problems with the FW 1.05 install. My sense is that provides a slightly better low-lighting focusing capability compared to 1.04 with a slightly higher amount of slow focus hunt in extremely low light - instances where you got no AF response in the past. (This was based on some testing done when going from 1.04 to 1.05.)
10-25-2013, 07:07 AM   #9
tomwil's Avatar
Whats seems strange to me, is that firmware 1.05 is available on the Japan website, but the files are not found on the USA website, giving a dead link. Its as if the files were pulled due to a problem with the firmware.
10-25-2013, 07:40 AM   #10
bluenose's Avatar
QuoteOriginally posted by tomwil Quote
When I clicked on your link the download page comes up with v1.04 at the top. Scroll down on that page and you will find v1.05
Regards
10-25-2013, 07:58 AM   #11
tomwil's Avatar
QuoteOriginally posted by bluenose Quote
Have you actually clicked on the v1.05 links? I get "Not Found The resource could not be found", as if the files do not exist and have been pulled from the site.
10-25-2013, 08:29 AM   #12
bluenose's Avatar
Sorry, I should have tried the actual download link instead of assuming that if it was there it would work.
Regards
10-25-2013, 03:18 PM   #13
In my experience, I would trust what's going on at HQ, not read much into what isn't properly linked at the Colorado outpost. If it had been offered and then pulled for a reason, the proper thing to do is explain - not just leave a dead link sitting there.
10-29-2013, 09:57 AM   #14
MaKettle's Avatar
What's going on with v1.05? I tried today to upgrade this version and still get the "resource could not be found" problem
10-29-2013, 10:53 AM   #15
QuoteOriginally posted by MaKettle Quote
Already installed v1.05 on mine try this link it's at the bottom of the page just make sure you download for the appropriate OS. I just tested the download to my desktop and it downloaded fine.
Latest K-30 Firmware Update : Software Downloads | RICOH IMAGING
firmware, k-30, k-50, pentax k30, pentax k50
K30 freezing since firmware update 1.05 poziax Troubleshooting and Beginner Help 12 02-02-2014 05:00 PM
K5II V1.05 Firmware Update Problem moparjer Troubleshooting and Beginner Help 7 09-18-2013 01:11 AM
K-5 IIs firmware 1.03 improves tilt flash overexposure issue bjdavey Pentax K-5 11 03-11-2013 10:42 AM
Firmware updates for K30, K-01 and Q RKKS08 Pentax News and Rumors 4 10-29-2012 05:59 PM
Anyone noticed Pentax quietly update K200D firmware from 1.01.00.05 to 1.01.00.06? arm_jstp Pentax DSLR Discussion 10 09-23-2010 12:28 PM
All times are GMT -7. The time now is 08:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
