10-25-2013, 12:01 AM   #1
Pentax K-5 IIs or Pentax K-50
Hi,
In my country, the K-50 is available for USD 750 and the K-5 IIs for USD 1350.
Is K-5 IIs worth the extra USD 600?
These are the comparison points:
- Focussing speed
- Low light focussing accuracy and speed
- Buffer writes speeds
- Start-up times
- Usefulness of top LCD
- Usefulness of dedicated buttons
- Image quality differences (both use the same sensor or very similar ones)
Thanks,
Anirban
10-25-2013, 12:16 AM   #2
OK, I'll base my suggestions on the criteria you gave:
- Focussing speed : 50/50, specially with screwdrive and in good light.
- Low light focussing accuracy and speed: K-5 IIs wins, with better low-light AF ability.
- Buffer writes speeds: K-5 IIs has bigger buffer and clears faster.
- Start-up times - Same...
- Usefulness of top LCD: Mostly useful when shooting in the dark and you set the LCD off because it can hurt your eyes; also, useful when shooting on a tripod at a low height
- Usefulness of dedicated buttons: ++ for K-5 IIs. Dedicated RAW button, AF button, metering switch are handy when changing settings quickly
- Image quality differences (both use the same sensor or very similar ones): + for K-5 IIs for having 14-bit RAW. More DR range can mean more recoverable info
hope that helped
10-25-2013, 05:55 AM - 1 Like   #3
wax
I have the same doubt on K-5II vs K-50
Im not worry about not having 14bit of DR or big buffer, but the advantage K-50(30) Focus peaking ability, for legacy lenses usability, have me on hesitation. I lost to much not geting K-5(something) intead of K-50(30)?
10-25-2013, 12:59 PM   #4
carrrlangas's Avatar
Top LCD, bigger battery, stronger body, grip option, more direct access buttons are the points Id take into account for the K-5II. How important are these for the kind of photos you take now?
10-25-2013, 11:00 PM   #5
I used to think I could live without top LCD -- just realized how much I need it. When looking through the VF, I never look at the shutter/aperture values -- in an unconscious way, they distract me from the scene (I shoot streets, mostly).
10-26-2013, 09:34 AM   #6
How long is the shutter expected to work in the k-50 vs k-5II ?
10-26-2013, 10:01 AM   #7
QuoteOriginally posted by anirbax Quote
I understand, I try to decide on settings before I take the camera to my eye so the upper LCD is invaluable to me... I guess you are set then...
11-07-2013, 06:44 AM   #8
kshapero's Avatar
Price now between K-5ii and K-50 is very close.
11-10-2013, 09:34 PM   #9
QuoteOriginally posted by kivis Quote
Unfortunately, in India now, the price difference is close to USD 600 :-(
11-13-2013, 05:36 AM - 1 Like   #10
QuoteOriginally posted by wax Quote
If usability of legacy lenses is important to you, then K30/K50 have an issue in that they do not offer depth-of-field preview as a position on the on/off switch. On my K200D, I would use the depth of field preview for metering a scene when using a legacy lens. Green button just sets exposure, it doesn't let you meter different parts of a scene.
While you can program the RAW/Fx button on the K30 to give you depth-of-field preview, for some stupid reason the meter in the viewfinder is NOT active when you use it. So your only option is using the green button to set exposure - no active metering with a legacy lens. I assume it's the same in the K50.
Aside from its tendency to overexpose, this is the only beef I have so far with the K30.
11-19-2013, 05:32 PM   #11
I have a K-5, because my wife insisted I buy the most expensive because she knew I would always doubt my choice otherwise. (Yes, she spoils me) Recently I bought her a K-30, because it is nice and blue, and because it was great value at about 400 dollars equivalent. I really love the K-5, but I think as value for money the K-30/50 in a bundle with the right lenses is much better value.
You live in India, and I assume that the local conditions are the same as where I live (I live in China) I expect it is rather dusty, so you don't want to be changing lenses much, and WR would be very useful. So I would get a K30/50 with an 18-135 WR, and a 55-300WR as soon as it becomes available. A very wide range of focal lengths, and no need to change lenses very often.
11-19-2013, 05:37 PM   #12
crewl1's Avatar
QuoteOriginally posted by arkav Quote
Is this a common issue with the K-30?
Pentax cameras as a rule are thought to underexpose more commonly.
If this is not a common issue with K-30, then try different metering options, or check if the lens you are using perhaps has sticky blades?
11-19-2013, 07:21 PM   #13
if i could do it over again... i would chose the k-5II over the k-50, simply because the k-5 is a more solid camera and will most likly have Offical Ricoh support longer than the K-50. Also i like the looks of the k-5II better. there are a lot of programmed shooting modes in the k-50 like my k-30 , that i just don't use. and if you find a k-5IIs new,, and its close to the same price,, then there would be no contest. the k-5IIs would win my vote. and of course there is the whole Vertical grip issue, which to some would be a deciding feature.
Several people have reported a bad "apature drive motor" causing both underexposure and over exposure issues in the k-30. if Ricoh used the same system for the k-50 then that is something to keep an eye on.
12-02-2013, 11:49 AM   #14
QuoteOriginally posted by crewl1 Quote
It seems to only affect macro photos taken in bright sunlight. As I've mentioned in another thread, I think I'm mostly doing things as I did with my K200D. If, as you say, underexposure is more common, it could be that the K200D was erring in the side of caution, and it wouldn't have a problem with harsh lighting. If the K-30 is slightly less conservative, it may be that it's overexposing and blowing out highlights in situations where the K200D wouldn't. The lens in question is a DFA 100WR macro. I need to play around with it more next season to see if I can set it up so that it doesn't do this.
k-30, k-5, k-50, pentax, pentax k-5, pentax k30, pentax k50, usd
New Pentax K-5, K-5 II & K-5 IIs Adobe Camera Profiles PentaxGuyUK Post-Processing Articles 7 12-04-2014 05:02 AM
New Firmware for K-500, K-50, K-5 II, K-5 IIs, K-5, K-30, K-01, K-r, and 645D is out Adam Pentax News and Rumors 60 09-16-2013 05:46 AM
New Firmware For K-01, K-30, K-5, K-5 II, K-5 IIs, K-r Adam Pentax News and Rumors 63 02-18-2013 02:04 PM
K-01 Now or Wait for K-5 IIs or K-30? Biro Pentax K-01 10 11-21-2012 09:31 PM
Pentax could we get the K-5 II / K-5 IIs in color please? Hegemon Pentax DSLR Discussion 17 10-14-2012 01:59 AM
All times are GMT -7. The time now is 11:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
