11-01-2013, 09:34 PM   #1
misbehave's Avatar
Hot pixel on K-30 LCD screen.
Today I found out there is a very very tiny white/hot pixel on my one year old K-30 LCD screen.
Anyone else have this same problem?
Is this a common problem with Pentax cameras? Should I send to back to Pentax for repairing? I am not even sure if mine still within the warranty period of not.
11-01-2013, 10:20 PM   #2
Vylen's Avatar
QuoteOriginally posted by misbehave Quote
If it's only one pixel then it's within fault-limits.
It should be mentioned in your owners manual that this is "normal".
11-01-2013, 10:40 PM   #3
My K-5 had this. Even if you were to get a new one, it might have and/or develop a hit pixel.
11-01-2013, 10:53 PM   #4
misbehave's Avatar
Thanks for the info.
I guess I can live with it as long as it is not affecting the actual image.
But is this going to get worse? Like more white pixels appearing.
Is there some kind of preventive measure for this problem?
11-01-2013, 11:27 PM   #5
It happens to all LCDs eventually, it is unavoidable. Some are there from the time of manufacture, some take years to appear.
11-02-2013, 08:20 AM   #6
JimJohnson's Avatar
This may or may not work with your camera.
Hot pixels on a display can sometimes be shocked into working again. Create a very brightly lighted WHITE surface, but don't do something silly like point your camera at the sun. Turn on Live View, but turn off all enhancement features and overlays. ALL you want is the white image. Manually mis-focus to blur everything and set the aperture to wide open. Now for about 4-5 minutes, let the the camera see this solid white image. Use your hand to cover the lens for a second or two every five seconds or so. A tripod may make this chore easier to do.
See if your hot pixel shuts down each time you go dark. If the pixel doesn't correct itself. If not, after 4-5 minutes, shut the camera down to let your sensor cool for a few minutes. Then repeat. I've had some LCD panels take upwards of an hour to fix hot pixels - and to be frank, on some LCD panels this shocking trick will never work. Or where it did work, the pixel returned to its hot status at some point.
11-03-2013, 08:45 AM   #7
i used to have an old sony a100 ,, bit different than your situation. but occasionally it would get a hot pixel on the sensor and all i would have to do is change the date in the camera and then later reset it and the hot pixel would go away..
But i never had a hot pixel on the display screen.
k-30, k-50, lcd, pentax, pentax k30, pentax k50, pixel
K5II preview monitor has dead Pixel & moisture in viewfinder and LCD screen Amante Troubleshooting and Beginner Help 16 09-04-2013 09:09 AM
Foggy LCD screen on K-30 ASheffield Troubleshooting and Beginner Help 7 08-01-2013 12:58 PM
Scratches on my K-30 lcd (cover?) MViborg Troubleshooting and Beginner Help 5 06-12-2013 07:41 AM
K-30 LCD Screen protection borish Pentax K-30 & K-50 8 11-07-2012 03:27 PM
Stuck Pixel on my K-7 LCD jeffshaddix Pentax DSLR Discussion 10 06-30-2010 07:49 PM
All times are GMT -7. The time now is 12:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
