11-07-2013, 02:28 AM   #1
rear curtain sync
Hi all, i recently bought a Yougnuo YN560-III and i was wondering how to get it to fire in rear curtain sync, any help would be great
Thanks
11-07-2013, 03:16 AM   #2
Unfortunately this feature requires a P-TTL flash to do it directly. You can do it indirectly by triggering the YN-560 optically in S2 mode with the pop up flash. The shutter speed must be faster than 1/30s for it to work, at least in my experience, otherwise there YN-560 times out waiting for the second flash because the pre-flash happens before the exposure.
11-11-2015, 11:51 AM   #3
panonski's Avatar
QuoteOriginally posted by elliott Quote
hi there, I'm litlle confused about second curtain flash - It appeals that in flash menu of my K 3, there is not option called Second curtain, or Rear curtain - there is only Trailing Curtain...
And trailing is firing flash instantly with shutter released ...
Where it s ?
---edit
I FOUND IT. It's only available in P, AV, and SV mode... It is not just Second curtain, they name it Trailing , and Second curtain flash, as a clean option not exist.
It has flash when you're opening exposure, and flash before closing it. So it kind of double your objects, once when they start to move in frame, and once when exposure is done..
Pity
Hm hm hm...
11-11-2015, 08:07 PM   #4
I think trailing is the same thing second curtain. The normal flash fires when the shutter opens and the trailing or second curtain fires just before the shutter closes. The pre flash fires before the shutter opens just to get the exposure right.
11-12-2015, 02:23 AM   #5
panonski's Avatar
QuoteOriginally posted by martym Quote
it's not the same thing, effect in the picture is completely different... I have this option in my older Ricoh, and in Olympus Pen,
it work fantastic if you know how to use it. I like effect of frozen subjects with trail behind, but when flash fires twice, instead of just once - your subjects have two frosen "static" place, and that's just not it - because if you clearly want just one, with litlle trail behind,
you won't get it, because flash fires twice
11-12-2015, 03:54 AM   #6
amoringello's Avatar
Rear, second, and trailing curtain are all the same.
Yougnuo's implementation is just faulty. It may be all they can do generically, but it is still "wrong" and not consistent with true 'trailing curtain' implementations.
11-12-2015, 06:31 AM   #7
panonski's Avatar
QuoteOriginally posted by amoringello Quote
maybe I'm wrong, I must checked once again is there any preflash exist on that option in these other two cameras I have
11-23-2015, 03:23 AM   #8
panonski's Avatar
yes, I was wrong about preflash, it's existing on my Oly too...
curtain, k-30, k-50, pentax k30, pentax k50, sync
Rear Curtain Sync Off Camera sandilands Pentax Camera and Field Accessories 22 12-20-2014 01:00 AM
Off Camera Flash Cable - Rear Curtain Sync Problem aaronkeogh Troubleshooting and Beginner Help 7 02-27-2012 09:55 AM
Rear curtain sync mindglow Troubleshooting and Beginner Help 8 12-28-2009 10:42 AM
Rear curtain sync trishytee Pentax Camera and Field Accessories 5 02-23-2009 07:28 AM
Rear curtain sync on the K10D imadethis Pentax DSLR Discussion 2 10-18-2007 12:25 AM
All times are GMT -7. The time now is 03:46 AM. | See also: NikonForums.com, part of our network of photo forums!
