Originally posted by ChopperCharles Similar how? Pentax ups the ISO one notch to create a noisier image. Nikon actually changes the exposure settings. For Pentax, it means you can never take a shot at ISO100. Nikon doesn't affect ISO, aperture/shutter speed is modified, so you can still shoot ISO100. What's more, you can tell the Nikon exactly how strong you want the effect, where the Pentax has only one setting.
I'm not getting how those are similar at all.
Charles.
Well, if you read the review - and a lot of evidence offered in other expert analyses, Nikon essentially ignores reporting to the user that the manipulation is taking place, and reports the set ISO even though that has been altered. This is why Nikon users complain that ADL is causing greater noise in the shadows. The honest answer is that the ISO has been shifted (hence more noise). If you read the DPreview analysis of the 7000 vs. the K5 (same sensor), it is clear that Nikon is making the shift automatically (not reporting to the user and not telling the user it is shifting the ISO), and so Nikon matches nearly exactly what the Pentax user is doing by turning on Highlight Correction. DPreview also correctly states that Highlight Correction makes the change to RAW and JPEGs, shadow correction is strictly a post-process (JPEG) function.
Maybe this analogy will help. Arizona has no Daylight Savings Time. Utah has Daylight Savings Time. In the summer, the sun comes up at the virtually the same time just across the border, but the clocks are set differently. You can say that the sun goes down later in Utah, but that's due only to the fact that the clock has been artificially shifted. So, Utah and the rest of the country is kind of like Nikon, and Arizona is kind of like Pentax. And Sony RAW sensors are capable of accepting only a finite dynamic range of light. The only way to avoid blow-outs in a scene that extends beyond the sensor DR limit is to underexpose (i.e. change the clock).
What is difficult to comprehend here? RAW is what comes off the sensor. Nikon alters the directions to the converter while Pentax gives the user the option to do so. The result is virtually identical. What is not clear here?
