Quote: Or is that only a canonikon feature?
There is a setting in the K-3 menus that gives you the option of not blowing your highlights… I've seen it in the menus but haven't checked it out to see how it might work.
But just in case you're looking for a bit of advice on how to shoot this…
FIrst, you're shooting in direct sun. There isn't a camera or film that's ever been made that can capture the whole dynamic range of this image without filters.. From the highlights to the shadows the ratio from light to dark is probably 20,000/1. So that's your first problem.
Spot metering on the birds head would help some, but you shot this at 0 exposure compensation. What you need to be doing is checking your histogram after taking the image, pushing the EV button on the top of your camera and rolling your EV down, on this shot to minus 2 probably, maybe more, because you have shadow behind the bird is pulling down your metered exposure value, even though it isn't really an important part of your picture.
The camera has to make a decision based on what you tell it when it looks at a scene like this. But you have to tell it. But the image is pretty much ruined by the high contrast caused by direct sun. You're simply asking too much of your sensor. Your assertion that a Canon would do better, i.e. lowering the exposure, keeping the white feathers from being blasted and totally blacking out the area around the eye and beak is not very informed. You wouldn't get a better image doing that. Once you lose details in those areas of the image, they just look like black holes. Given the lighting conditions, your camera made some pretty good decisions.
In fact, any K-series camera K-5 and beyond (K-5, K30, K500, K-01, K-5II, K-5 IIs) is going to give you superior dynamic range, compared to even the most expensive Canons, giving you a bit more latitude to work with in images like this.
I'd be interested to hear what guys who use neutral density filters would say about this. Could this image have been rescued with the use of filters?
