Originally posted by paulh I'm no expert, but I've always heard that CA is a lens issue, not a camera issue. I'm thinking that the K500's improved sensor and higher resolving power (over the K-r) is exposing the lens' deficiencies, and that's what you're seeing. I may be completely off-base, hopefully someone more knowledgeable than me will jump in. I also have the DA35 2.4, and it's a fine lens. I rarely encounter CA using it with my K10D.
Originally posted by paulh s' def
Thanks for your reply. Indeed I've thought the same thing, the K500 sensor showing the lens deficiencies...
But for me, not an expert, it seems really strange that an almost non-existing issue (whithout any CA correction) in the Kr becomes a major issue in the K-500 used in the same conditions (the DA 2.4 35mm is not a so old lens).
If the K500 shows the deficiencies of the lenses, I would consider anyway to return it. What the point of improving my kit if it produces worse images than my old one?
Let's hear what experts think
