11-22-2013, 08:07 AM   #1
manual lenses on K30, no shutter
The shutter isn't clicking on a manual lens on my K30. The lens works on my K-x. Is there something different about the two cameras, or the settings? I was hoping to use the green button, and focus confirmation, and use the lens on a K30. Perhaps I need to short the contacts differently? The lens is an Albinar K-mount 135mm F/2.8
Also, how do I get to the screen where I manually input the focal length on the K30? It won't let me open that menu on the camera.
- Sheldon
11-22-2013, 08:19 AM   #2
bluenose's Avatar
This link may be of use. Using K-30 With Older Lenses | Ricoh Imaging Support
Regards
11-22-2013, 08:21 AM   #3
QuoteOriginally posted by sheld Quote
- Sheldon
It sounds like you have shake reduction turned off.
Everything should be the same as the K-x if the settings are the same.
11-22-2013, 08:59 AM   #4
altopiet's Avatar
If you are shooting in M mode, make sure the ISO is not set to auto...if it is in Auto mode the green button metering won't work.
Did you enable #23 in "C" under menu?
Under Menu "Camera" #3, the last option, you should be able to change the focal length, if you enabled the option in #23, as mentioned above, it should also allow you to do that at start up, if a manual lens is fitted.
11-22-2013, 10:39 AM   #5
- Sheldon
Follow this guide:
https://www.pentaxforums.com/forums/54-pentax-lens-articles/110657-how-use-me...k-x-k-7-a.html
Make sure you set the custom setting & that you're in M mode.
12-12-2013, 10:30 AM   #6
fyi, belated thanks for the video/text instructions! I updated the two menu settings,
o Menu 23, set "use aperture ring" to enable
o E-Dial programming, set M<>TV to TvShift mode
o switched to "M" mode and manual ISO.
Now my three m-mount lenses work fine. My m42 screwmount lenses don't work, but there's another thread on the K30 and m42 screwmount lenses.... https://www.pentaxforums.com/forums/151-pentax-k-30-k-50/245275-green-button-...-mode-m42.html
- Sheldon
k-30, k-50, k30, lens, pentax k30, pentax k50, shutter
K30: Cant use aperture/shutter dials after taking pic in manual kef Troubleshooting and Beginner Help 3 10-19-2013 09:44 AM
Shutter speed mode using manual lenses WangJianWei Pentax K-01 2 06-11-2013 11:37 PM
manual lens on my k30 TGoode Troubleshooting and Beginner Help 3 01-26-2013 03:53 PM
Shutter Count on a New K30 FlyingRV Troubleshooting and Beginner Help 5 11-30-2012 07:37 AM
Why no metering when we press the shutter on old lenses? alphanerd Pentax SLR Lens Discussion 3 05-10-2012 06:46 AM
All times are GMT -7. The time now is 01:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
