11-24-2013, 09:15 AM   #1
k50 manual m42 lens
hi i am testing a helios 50mm f2 but i can't take a reading for speed shutter with the green key... i am not sure what can i do, i don't want take photos in Av mode i prefer M mode
any idea????
thanks
11-24-2013, 10:44 AM   #2
sterretje's Avatar
Maybe this helps (not sure if you've read it already)
https://www.pentaxforums.com/forums/58-pentax-beginners-corner-q/110658-using...x-dslrs-f.html
11-24-2013, 11:48 AM   #3
Na Horuk's Avatar
Here is another thread about this:
https://www.pentaxforums.com/forums/54-pentax-lens-articles/110657-how-use-me...k-x-k-7-a.html
Basically, you need to go to menu, enable aperture ring (at the very end of menu), then you go into M mode and select the aperture on the lens. ISO should be constant (not auto iso), and when you press green button, the camera will stop down the lens to selected aperture, meter, and adjust the shutter speed. Any mode other than M will default to Av. Av mode will always shoot wide open, but it allows auto-ISO and it meters continuously (you don't need green button).
With the m42 Helios you mentioned, the camera cannot move the aperture at all. It is a preset aperture, so you need to lock it and close it yourself, by hand. This is a little tricky with the Helios, because the written number is actually the opposite of what you have selected. I suggest you look into the lens while stopping down to figure out which end is wide open and stuff. With this lens, you can just keep the camera in Av mode, focus wide open, and then stop down the lens and take a shot. The metering will be continuous, because Av. M mode only turns off auto-metering with this type of lens. Feel free to experiment with Sunny 16 and other exposure rules.
Always focus wide open (at f2.0 in your case) because DoF is thinnest at that aperture and the focusing should be most accurate.
11-24-2013, 12:21 PM   #4
Kozlok's Avatar
My guess is the K50 firmware isn't working right. The K30 isn't. I wrote to Pentax about this, and they are aware. Not sure when they will fix it though! My suggestion is to write an e-mail to Pentax and complain.
Here's my thread on the subject: Super Tak Metering Problem
11-24-2013, 07:29 PM   #5
6BQ5's Avatar
Green button is useless for me too. I just use Av mode and I have learned when/where to use exposure compensation. Use your histogram and select the right metering type to learn any exposure quirks. It sounds bad but it all works fine.
11-24-2013, 10:49 PM   #6
the procedure( with the aperture ring and the green botton) works fine with K mount lens i have a auto chinon 50mm and works great, but i have this incredible Helios and in some sites i look that someone shortcut the contacts but i am not sure how to do that, i am want to break my new K50
02-01-2014, 11:02 PM   #7
Hi i fix it..... i just put some aluminum tape in the base of the lens and it work's great if someone need help send me a pm
02-02-2014, 12:52 AM   #8
QuoteOriginally posted by Kozlok Quote
They know about it?
They have a funny way of showing it. They are telling me to send in my new K50 to the UK service centre to have this checked out!
02-02-2014, 07:53 AM   #9
QuoteOriginally posted by fquito Quote
Huh how does putting aluminium tape help? Please enlighten me
02-02-2014, 09:23 AM   #10
sterretje's Avatar
It shorts the contacts on the camera. So now the camera thinks it's an K or M lens and you can use the green button metering. The other advantage is that you can use CIF.
03-13-2014, 07:37 PM   #11
you can buy an aluminium tape...
---------- Post added 03-13-14 at 07:41 PM ----------
now i have another problem, how i can look the EV meter ?
03-13-2014, 09:49 PM   #12
QuoteOriginally posted by alwaysjerricky Quote
QuoteOriginally posted by sterretje Quote
The only hazard is that you may lose infinity focus if the tape has much thickness.
03-14-2014, 10:53 AM   #13
I can, but I shouldn't have to.
I didn't have to with K200d or *ist DL2.
Pentax tell me this should work without aluminium tape.
03-14-2014, 11:04 AM   #14
sterretje's Avatar
QuoteOriginally posted by Fluke Quote
How did they tell you that? Email? User manual?
03-14-2014, 05:09 PM   #15
Pentax is telling you without knowledge.
k-30, k-50, k50, k50 manual m42, m42, mode, pentax k30, pentax k50
Can a manual m42 mount lens with a stuck aperture be fixed? Vantage-Point Pentax SLR Lens Discussion 3 09-15-2011 08:54 PM
How to fix a auto-only M42 lens so it becomes a manual one sterretje Pentax SLR Lens Discussion 5 05-16-2010 10:12 PM
Help K50/f1.2 lens quyi419 Pentax SLR Lens Discussion 22 07-08-2008 01:08 AM
Question About Auto/Manual Switch on Vivitar M42 Lens zx-m Pentax SLR Lens Discussion 2 06-11-2008 06:49 PM
All times are GMT -7. The time now is 08:31 PM. | See also: NikonForums.com, part of our network of photo forums!
