While I agree that 50mm on a crop sensor is not enough for a typical head and shoulders portrait, I also reject the idea of shooting from a minimum of 15 feet using a long lens. Anything past about 135mm on 35/FF, or about 90mm on crop sensor flattens features to an unnatural degree, and tends to bring up the exposed ear unnaturally. While an f/5.6 lens might be fine in ideal conditions (soft light, distant background), creating a good dimensional effect is best accomplished around f/2.8-4 (some photographers like even wider apertures but that isn't my preference - super soft noses are distracting). If you are really serious about portraiture neither the 18-135 nor the 50mm are an ideal tool. Most zooms are a compromise for bokeh, but there are notable exceptions. Macro lenses are typically great at what they are designed to do, but portraits are neither intended to be shot close nor do they need to have critical sharpness across the frame.
From Pentax, based on photos I have seen - the 77mm especially, and 70mm are fine tools (I don't own either one). If you are on a budget, finding a used A-series 35-105 f/3.5 (shooting in the 75-90 range) will give you an excellent tool for portraits - it just yields a much nicer look and blur than the typical zoom. Another fine option - again MF - is the Samyang (Rokinon, Vivitar, etc.) 85mm f/1.4 - bokeh in the f/2.4 to 4 range is superb.
