12-07-2013, 09:19 AM   #1
Setting minimum shutter speed?
On the K-30, is there a way to set minimum shutter speed? I've searched and can't seem to find anything. On a few other brands there is a feature to set minimum desired shutter speed. Say you are in A mode, the camera will ramp ISO up until it hits that speed. If it hits maximum defined ISO, shutter speed starts dropping down.
I use this mode indoors when shooting kids or pets. 1/60 or slower is just not effective with them, I have pretty good luck with 1/200. TAV mode seems close, but if ISO maxes out, the camera just underexposes rather than dropping shutter speed.
12-07-2013, 11:35 AM   #2
Senior Moderator
Parallax's Avatar
Aperture is already limited, i.e. there are only so many available, and the same is true for ISO. If you then limit the third and final variable, shutter speed, you will encounter situations that will not allow proper exposure, just as you described using TAv.
12-07-2013, 12:38 PM   #3
QuoteOriginally posted by yakky Quote
I think what you can do is simply use P mode and when the shutter speed drops below what you want for that shot, just rotate the front dial to get to a desired shutter speed. Might actually be more useful than a separate setting for minimum shutter speed as that limit you're thinking of is probably an ever-changing number, depending on each shot being composed.
12-07-2013, 03:30 PM   #4
Na Horuk's Avatar
TAv and Tv mode. You can help freeze action/ignore the shutter by using flash (fill flash, second courtain). You can try the panning technique as well.
In auto and P mode with auto ISO, the camera already has a "minimum shutter speed" which appears to be around 1.6*focal length. This means if you have a 50mm lens, the camera will go down to shutter speed 1/90, and then raise the ISO instead of going below that.
But unfortunately, there is no setting to give the camera a certain limited range in which it may operate. It would be useful in many situations.
The other thing is to shoot raw and then use post processing software the digitally brighten/darken the photos. Its quite remarkable how much you can squeeze out of a DSLR these days.
12-08-2013, 09:31 AM   #5
QuoteOriginally posted by IchabodCrane Quote
Great advice, that does seem to work even better than an absolute limit. Thanks!
12-08-2013, 09:33 AM   #6
Sure would be nice to be able to adjust that 1.6 multiplier!
camera, hits, iso, k-30, k-50, mode, pentax k30, pentax k50, shutter
control minimum shutter speed in aperture priority muzee Pentax K-01 9 06-01-2013 02:20 PM
Camera setting too slow shutter speed Jed Mooar Troubleshooting and Beginner Help 6 08-09-2012 06:51 AM
Fight shots setting the Shutter speed on a K-x ClinchShots Troubleshooting and Beginner Help 15 08-07-2012 05:53 PM
How to calculate minimum shutter speed for moving objects? Alberts Troubleshooting and Beginner Help 12 11-14-2011 01:52 AM
Minimum shutter speed with shake reduction eyou Pentax DSLR Discussion 12 07-30-2009 09:41 AM
All times are GMT -7. The time now is 03:17 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
