Originally posted by Jhimmy The main thing I was thinking and I should have tried to explain better, was the exposure issues especially in the UK, We have modern buildings to castles to pre roman, as a beginner in DSLR I know it's good to have experience, but the whole point in Scene modes to to "help" the beginner..
I disagree.. Scene modes don't help the beginner, they only make it easy for use in certain circumstances where the exposure settings are usually very similar. IMO there are too many variances one encounters when shooting architecture for a scene mode.
The best help you could give yourself is to learn about your camera and how to pre set it up based on your knowledge and what you want to capture, learn EV (exposure value), exposure reciprocals, how to compensate for effect, learn about your lenses, depth of field etc. Unless you want to be just a picture snapper don't make the mistake of letting your camera do the thinking for you or a good majority of your photos will not be what you really wanted to achieve. Then you need to learn good post processing techniques.
These great photos you see from other photographers didn't happen by someone going out, using a scene mode and snapping away. Most of the time they were pre planned, well thought out and at a time the photographers knew when the lighting was going to be just right for what they wanted to capture, using camera settings they set up to accomplish what they wanted to portray as close as they can.
