01-10-2014, 07:34 AM   #1
wireless flash help
Hi all, i recently got a metz 52 for my k30 and while it is great i am having some difficulty getting it to fire off camera with my yonguo triggers. Any help would be gratefully received
Thanks
01-10-2014, 10:24 AM   #2
THoog's Avatar
What model of YN triggers, and what sort of difficulty?
01-10-2014, 10:28 AM   #3
crewl1's Avatar
QuoteOriginally posted by THoog Quote
Make sure shutter speed is 1/180 or below?
01-10-2014, 02:20 PM   #4
Did you put the camera in wireless mode? Flash pad on 4way > move to wireless, then try.
01-10-2014, 02:31 PM   #5
crewl1's Avatar
QuoteOriginally posted by geru2000 Quote
OP using triggers not wireless.
01-11-2014, 03:32 AM   #6
adwb's Avatar
QuoteOriginally posted by nfraser Quote
Thanks
We need a bit more info as to what the "some difficulty" is?
01-11-2014, 04:59 AM   #7
QuoteOriginally posted by crewl1 Quote
Oops......so much for paying attention. :-)
01-11-2014, 12:55 PM   #8
sorry for the confusion, i have yonguo 603 triggers. The difficulty is getting the flash to fire, i have one of the triggers in the hotshoe and the other on the foot of the flash, both are on the same channel.
01-11-2014, 01:51 PM   #9
THoog's Avatar
Are the RF-603s the Nikon or Canon version? So far as I know, only the Nikon version will detect the 'awake' signal from a Pentax camera so that it can go into TX mode.
Can you verify that you have the camera shutter speed set to 1/180 or lower, and the flash is in M mode (manual, not P-TTL or Remote)? The left LED on both RF-603Ns should be green; the right LED on both should be green when you half-press the shutter button, then flash red when you fire the shutter.
If all this is true and the flash STILL doesn't fire, then I suspect it is a 'digital pin' problem. On the RF-603N's hotshoe, you will notice the contact closest to the power switch is smaller and flatter than the others. This contact is used for digital communications between the camera and flash. My older flashes don't have that contact, and they work fine on the RF-603N. Some newer flashes expect the RF-603N to put some information on that pin, or else they put something on that pin that confuses the RF-603N (I don't think it is that smart, to be honest); they won't fire unless you insulate the digital pin. A small piece of cellophane tape works fine.
help, k-30, k-50, pentax k30, pentax k50
Wireless Flash help with a K30 ronuser Troubleshooting and Beginner Help 13 03-23-2015 05:38 PM
Sigma wireless flash doesn't - help! Clive Washington Flashes, Lighting, and Studio 6 11-27-2013 07:59 PM
Manual Wireless Flash Photography... Help! reivax Flashes, Lighting, and Studio 12 01-30-2012 11:48 PM
Wireless Flash help yoon395 Flashes, Lighting, and Studio 12 10-16-2011 02:07 PM
K10D Wireless Flash help needed Sarahbell Troubleshooting and Beginner Help 16 07-27-2009 09:03 AM
All times are GMT -7. The time now is 06:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
