01-17-2014, 05:30 AM   #1
Help making the right decision K50 or K5iis
Hello all,..
I have decided to get a new pentax dslr (this will be first dslr)..
I do release the quality on k5iis is slightly better in terms of low light focus and dynamic range than the k50
I have four options infront of me and unable to make up my mind...
Pentax K-50 White + DAL 18-55WR + DAL 50-200WR Twin Lens Kit : 659 GBP
Pentax K-50 White + DA 18-135WR : 739 GBP
PENTAX K5 II DIGITAL CAMERA WITH 18-55MM WR LENS: 679.00 GBP
PENTAX K5 II S DIGITAL CAMERA WITH 18-55MM WR LENS : 799.00
My max budget is around 700 but willing to go to extra 100 quid just to get the extra performance if needed..
I probably wont be able to invest anything else into this for atleast 6-9 months so confused if going down the kit lens route with k5ii/s isn't such a great idea
Mainly my pictures will be while I travel.. nature, landscapes, buildings, kids and indoor once in a while...
Any suggestions here are greatly appreciated thanks
01-17-2014, 05:47 AM   #2
on a different note.. a friend has pointed me to a offer showing the D7100 + 18-105mm for 800 GBP .. just makes my decision tougher i guess
Apologies for making second post.. i am not allowed to edit my post yet
01-17-2014, 06:51 AM   #3
gbeaton's Avatar
I wouldn't pass up the chance to get Pentax's flagship camera K5ii at a good price. I think you have to decide what you want most, all purpose (#2), pro quality/performance (#3). I wouldn't spend the extra money on the K5iis and the 50-200mm zoom lens has a very poor review so forget that one.
01-17-2014, 06:56 AM   #4
gbeaton's Avatar
QuoteOriginally posted by gbeaton Quote
Woah! The 55-135 has a bad review too. Forget that one. Here is a very good resource you should check before you buy any lens... Pentax K Lens Tests
01-17-2014, 07:06 AM   #5
altopiet's Avatar
55-135
He's talking about the 18-135...
01-17-2014, 07:08 AM   #6
SpecialK's Avatar
Even the kit lenses get good reviews and have fans. All lenses have good and bad reviews. You should look in the lens sample image threads to see actual results people get.
At some point you will likely replace them with something more suitable (faster/longer/shorter) for your particular needs and preferences, but you are not there :-)
01-17-2014, 07:16 AM   #7
altopiet's Avatar
QuoteOriginally posted by sriks Quote
If it is a DA L lens, it's not WR....so it's either a DA L or DA....WR lens? I can only say that I would stay away from the 18-55 lenses, WR or not. I had a good DA L 200, but haven't tried the WR version, for general purposes I would pick the 18-135WR, as I should've done when I bought my K-30, which is about the same as the K-50. I would then save for the K-3 which should drop in price in a years time, or perhaps a FF Pentax if it eventually arrives.
EDIT: The 18-135 should give you an idea of what focal length you'll need, I originally went with a 18-55 and 50-200 kit with my K-x, but soon found the 200 too short, so if you're going to need longer than 135, you might just as well get a 55-300 at some stage later on...
01-17-2014, 07:21 AM   #8
Is #2 all purpose because of the lens ? or k50 is a more versatile camera compared to k5ii ..
Thanks for pointing to that site.. the 15-135 fared quite bad in their tests ..
Agreed so its important to get a better body and bad lens :P
01-17-2014, 07:31 AM   #9
I'd get the K50 + 18-135. Excellent as a first DSLR camera.
01-17-2014, 07:39 AM   #10
TER-OR's Avatar
The 18-135 is a nice lens. Is it a prime? No. Is it a big step up from most kit lenses - hell yes.
I'd get the 18-135 over the 18-55 and 55-200 set, then save up for a used 55-300 and you'll have a great starter kit - much better than the competition.
You'll have a weather resistant camera with a fantastic sensor, a solid motorized silent focusing lens which will make your friends jealous when they try it.
The K50 looks great in white, too.
I have a K5 and the 18-135 and 55-300 is my go-to general purpose kit.
01-17-2014, 07:49 AM   #11
QuoteOriginally posted by altopiet Quote
i guess the site listing them is confused in someway, will give them a call to see if its DAL or WR
(Pentax K-50 White + DAL 18-55WR + DAL 50-200WR Twin Lens Kit | Buy Pentax K50 at Clifton Cameras) they list as DAL WR
I do have plans for getting better lenses down the line..
QuoteOriginally posted by TER-OR Quote
i love the Starship Trooper look of the k50 but having the top end k5ii with its improved AF and low light just in the same price range kind of puts me in an unwanted place..
01-17-2014, 08:00 AM   #12
altopiet's Avatar
have a look at post #7 in particular, but also the other posts https://www.pentaxforums.com/forums/130-lens-sample-photo-archive/191544-pent...-18-135mm.html, that is the 18-135 with the K-30, which is almost identical to the k-50...
01-17-2014, 08:07 AM   #13
Otis Memorial Pentaxian
The K-50 may come bundled as a two-lens kit with DAL WR versions of the 18-55 and 50-200 zooms. The lenses have a grey band as opposed to the green band on the non-L versions. I know because I just helped a friend purchase this kit.
01-17-2014, 08:10 AM   #14
Another vote for the K-50 + 18-135 WR for GBP 739. That looks like the best deal.
01-17-2014, 08:11 AM   #15
Imo, for your usage and being first DSLR, I'd just stick to K-50 with 18-135mm. That lens is quiet, focuses fast and sharp for commonly used range. The AF and high iso performance of K-50 compared to K-5ii I don't think is *that* drastic. K-5ii does offer some extra convenience features that K-50 doesn't have and the shutter is quieter.
But from my observations there could be such thing as having too many features when starting out -- I've seen people end up making so many mistakes because the camera lets the user control it and the user gets frustrated with the results. So it might be worth asking if you may fall into this category or not before jumping on K5ii. Or perhaps the joy of using a camera maybe increased due to having a cool looking camera. I know I felt that way when I had my K-x.
18-55mm, camera, decision k50, gbp, ii, k-30, k-50, k5, k5iis, lens, pentax, pentax k30, pentax k50, wr
Making a decision on the K-5 ruemiser Pentax DSLR Discussion 4 10-31-2012 04:33 AM
Ok guys, I'm making a decision soon - K7 with 50-135mm or K5? crossover37 Pentax DSLR Discussion 68 05-05-2011 04:41 PM
K20D, am I making the right move getting it? Karn Pentax DSLR Discussion 66 08-09-2008 04:44 AM
Have I made the right decision? Igilligan Pentax DSLR Discussion 3 02-03-2008 11:32 PM
Need help making a decision paden501 Pentax DSLR Discussion 22 01-29-2008 07:55 PM
All times are GMT -7. The time now is 01:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
