01-17-2014, 04:23 PM   #1
Kr lowest ISO is 400
I had not used my Kr in a while and when I recently did I noticed the lowest I could set the ISO was 400. After changing the sensitivity in the Menu to extended the lowest changed to 200. Am I forgetting something obvious because I haven't used it I for several months?
OK, right after I posted this I discovered that by turning off highlight and shadow correction the ISO setting behaves as it should. If this is as it should be please ignore this post.
01-17-2014, 04:24 PM   #2
QuoteOriginally posted by Tim A Quote
Disable shadow/highlight correction and you should get access to ISO 100.
01-17-2014, 04:59 PM   #3
Na Horuk's Avatar
Yes, two things affect ISO on the K-r:
a) Expanded (boosted) ISO
b) Highlight correction.
With highlight correction, it actually uses an ISO one lower than the one displayed, but then it digitally brightens the photo, without clipping the highlights. Clipping means when the highlights are completely burned out, completely white. So the highlight correction is only an "illusion" of ISO being higher.
And expanded ISO should just be enabled. Using ISO 100 on the K-r is great.
01-17-2014, 05:31 PM   #4
Thank you Na Horuk and Adam. It is good to know what is exactly what is going on. Sorry for posting in the K30 forum by mistake.
iso, k-30, k-50, kr, kr lowest iso, pentax k30, pentax k50
What is the lowest iso wombatwal Pentax K-5 3 09-30-2011 01:43 AM
Is this kind of unusually high noise expected for K-x at ISO 400 ? photoleet Pentax DSLR Discussion 38 09-26-2011 11:04 PM
missing lowest ISO setting on K-5 / K-7 penties rider Pentax K-5 7 05-08-2011 08:03 AM
[Auto-ISO] so, is the K5 and Kr brave enough to use max iso? Reportage Pentax K-5 13 10-24-2010 03:30 PM
K10 D is only good at 400 ISO Captain Pentax DSLR Discussion 21 07-22-2008 01:07 PM
All times are GMT -7. The time now is 02:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
