Originally posted by Kozlok For me, indoors a 50 is usually too long and I can't back up enough. Outdoors a 50 is usually fine. For me personally I did a series of tests with my zoom to see what FL I preferred. I found that I either preferred the 35mm length or my preference skipped to 70. Almost never did I "prefer" a 50mm shot. Go out and take the same picture with your zoom set at 35 and 50. Move around to frame each shot specifically for each FL. Do this 10 or 20 times, look at the results.
One more thing, if you get the 35, you can add a cheap 50mm manual focus (the Takumar 55/1.8 is a favorite of mine in this FL for ~$40, or an M50/1.7 is ~$50).
I like the 35mm FL and I like your idea about the cheap manual prime lens, what adapter do you recommend for M42 to K mount and where would I shop for the older lenses?
