Originally posted by Bonavista Forgot to change from 85mm to 135mm on startup
with flash it does not matter.
nice cat.
---------- Post added 02-27-14 at 10:33 PM ----------
Originally posted by Bonavista Set the flash from the back moving the slider to the left all the way to 32
upper slide it is ONLY mechanical calculator for NON automatic bodies, K1000 or MEsuper for example. or for non "A" lens, M40/2.8 for example.
Upper slider DOES NOT affect exposure at ANY kind.
If You use K-50 and A lens or FA lens or DA lens:
1- set camera at Tv mode (!)
2- set RED or GREEN mode on the flash. change between them if needed
3- set lens aperture dial at "A"
try to change ISO and see, as aperture changing.
IMPORTANT ! - if from some reason FIRST TIME ONLY it will not work, press the shuter button, remove the flash and so on, clean th contacts at hot shoe - but after that it will work always and AUTOMATIC/
please note - tecnically camera is at Tv mode, but practically if You change the ISO - You change the F stops too. You will be able to set shutter slower, than 1/180, but faster will not.
so - it is ISO-Av mode... just try.
see my video before.
BUT - if You use legacy lenses:
1- set ISO at the camera and flash the same (Yeah, upper diale does not affect the exposure, but You need to read it right)
2- read F number form calculator depend of GREEN or RED mode You are using.
3- set this F number at the lens.
for Pentax DSLR usually need to open aperture for 1 stop, so, if calculator shows to You at RED mode/ISO 100 need F number F/4 - so set the 2.8 and be happy. (as You are DID) It will be 1 stop more light. If It too much - close aperture to 3.5 or back to the f/4
note Pentax DNG more better pull to the light, then push to the dark.
(I hope my English is understandable)
