Originally posted by beebs Ah, thanks for that. I will probably go with an extra OEM for now...had less than stellar results with the rechargeable AA's...not sure whether to attribute it to the cells I'm using (the 2300mAh Energizers) or the aftermarket clips...more than likely a little of both. Sometimes it works great, other times, I can take the AA's right out of the charger, put 'em in the clip and put 'em in the K-30 and turn it on, and get "BATTERY DEPLETED"...go figure.
I have the aftermarket clip. At least initially, the connections are super strong (over time care to keep the springs upward is a good idea). I don't know of anyone having a problem with the generic. The issue is that the circuit is designed for about 7.4 volts. Four NiMH AAs yield about 5 volts fully charged and can drop off under strain (but then recover). Heck, the circuit would be just right with six cells (7.2 volts). In any event, most if not all L-ion AAs are 2000mAh if they are hybrids (precharged). Anything above that rating tends not to hold charge as well, and will take fewer charges. Precharged Eneloops/Duracells rated at 2000 work best - but still a bit dodgy under stress (heavy shooting, use of flash - on board or external, etc.) even when new and recently charged.
