Originally posted by Nick Siebers +1 to the F 35-70. Nice little lens, good with close-ups.
If you're looking for that kind of dual purpose zoom lens, the 35-70 A F4 is also pretty good if you don't care about auto focus. Still not a true macro lens, and I'm not sure how cheap it might be.
Originally posted by PPPPPP42 I will also remind you, it is ALWAYS better to save up for a good lens than to settle for a cheap one even if it takes much longer. A good lens will stay with you a long time as evidenced by the fact that most of my lenses could have taken pics of Reagan while he was in office and that's only because I don't want to use older than A series with a DSLR for the sake of speed and convenience.
+1 on this . I mucked around with a variety of lenses ( including the zoom mentioned above ), extension tubes, etc. back in my film days before I broke down and spent the money on a M series 100mm F4. I never looked
back, and used that lens till the wheels fell off. When it was in danger of falling apart, rather than spend several hundred on the repairs, I went for the 100mm DFA WR. The new lens is definitely better, but in retrospect, I have to admit that the old beater produced surprisingly good results.
But going the dedicated macro route might only make sense if you do a fair amount of closeup work. The trick is, how will you ever know if you really want to do a lot of macro work until you get a lens that is
capable of producing decent results? That said, many modern lenses seem to be capable of near-macro closeups.
Cheers
