Originally posted by JimJohnson The manual for this flash is difficult to understand
No argument there. It took me several times through the flash manual and an attempt to use all of the supported features before I got a reasonable degree of mastery. May I also add that the manual itself is bulky and flimsy? The pages are falling out of mine. I am going to make myself a single sheet guide suitable to slip into the camera bag.
In regards to the focal length, the information is on page 15 of the flash manual in the section titled "Setting of Flash Coverage Angle". The first bullet point explains that the displayed "ZOOM" value represents the 35mm equivalent focal length for field-of-view. When manually setting the "ZOOM", it is important to keep this in mind. For example, if I am shooting with a manual focus 50mm lens, I should input 70mm as the "ZOOM" value.
---------- Post added 02-19-14 at 07:39 PM ----------
Originally posted by icy The manual told me to use M-mode in the camera and flash to use FP mode (fast sync, aka. HSS).After many tries I thought my flash was broken. Fortunately, using TTL mode and using +/- buttons will give FP mode. I found that by accidence. So, the manual must hide something.
The English section of my copy of the flash manual (p17-p18) says to consult the camera manual for camera settings to support HSS.* It goes on to state that supported flash modes are P-TTL, Contrast-Control-Sync, and Wireless. It then says to use "+" or "-" buttons on the flash to display the "FP" indicator on the flash LCD. Looks to be pretty explicit (nothing hidden).
* For the K-30 and K-50 that would be Tv or M mode with the shutter speed set to greater than 1/180s.
