Originally posted by elliott I'm thinking you're hearing the stop down lever moving. The camera should be silent when the green button is pressed and the contacts are not shorted, M42 lenses usually have anodized mounts and should not be shorting the contacts. What lens and adapter are you using?
With M and K series lenses all of the contacts are shorted, so it assumes it has control of the aperture lever. Do you have any M or K series lenses? Is the sound the same as you are hearing with the M42 lens?
I'm using a takumar 50mm f1.4 so a m42 lens with pentax brand adapter. I've been using this lens and adapter since I bought the camera and it never tried to move the stop down lever. It always just meter without any noise or movement of parts. It's firing the shutter like I'm taking a photo. I see the viewfinder blink like I took a photo.
---------- Post added 04-07-14 at 09:52 PM ----------
Okay I think I figured it out. I've been tightening my lens down a little bit tighter recently so that the aperture number is on top of the camera. When I do this, I'm guessing it's shorting the contacts. So I have to loosen it slightly for it to stop doing what its doing. Now the thumb lever for manual/auto on the lens is covered by a part of the camera but it's working like it did before.
Is it suppose to stop down with a m42 lens or not? I prefer to have the lens tightened so the aperture number is on top and the manual/auto switch is assessable.
