04-16-2014, 05:49 PM   #1
Odd shutter speed issue?
I've only just started to notice this issue with my K-30 and the 1.06 firmware. When I shoot, it has started to jack up the shutter speed (just now it went from 1/60 to 1/500 without any input, then back to 1/60 the next shot)
Is this a bug, or am I just missing something?
04-16-2014, 05:52 PM   #2
QuoteOriginally posted by SpartanD63 Quote
Are you using the flash?
04-16-2014, 05:54 PM   #3
No... I just noticed the issue... It was set to do the exposure bracketing thing, but I saw it as the continuous mode. (My go-to) I'm blind.
04-17-2014, 05:18 AM   #4
schnitzer79's Avatar
what mode is your camera in?
04-17-2014, 05:43 AM   #5
QuoteOriginally posted by schnitzer79 Quote
It's in Manual mode. I figured out that it was set to bracket exposures, but now I'm confused, as I thought exposure bracketing set the shutter speed to 3 different values, rather than switching between two... Hmm....
04-17-2014, 06:23 AM   #6
its like for an instant its taking a reading off different subjects different lighting as if its in AV mode.
does the same thing happen in TV mode or only in M?
04-17-2014, 07:50 AM   #7
photolady95's Avatar
Location: Cruising PentaxForums and watching your back.
I don't believe that's correct. On my K-30, with camera set to M mode, bracketing doesn't change the shutter speed at all. It takes three shots, each at a different EV value but shutter speed remains the same for all three shots.
04-17-2014, 07:57 AM   #8
I'm not sure. I'll have to test when I get home. (I'm out with a film body today.)
I'll have test more thoroughly, as I found it strange, only getting two shutter speeds.
04-17-2014, 08:51 AM   #9
QuoteOriginally posted by photolady95 Quote
how can the ev change when everything remains the same?For instance in M mode if u set ur bracketing to start with a correct exposure then underexpose and then overexpose, the camera needs to adjust both aperture and shutter speed in order to do so for the 2nd and 3rd exposure....so i doubt they stay the same
As for the problem you have SpartanD63 also have a look at the EXIF info just to make sure that the shot was taken in M mode depsite what your camera is telling you.just in case the dial might be playing up
04-17-2014, 09:26 AM   #10
I didn't see any change in shutter speed on the ones I checked through EXIFtool, but of each bracketed shot one was underexposed, one was normal, and one was overexposed. Still none had a change in shutter speed. So, I am not entirely sure how bracketing works in what all changes for each shot.
04-17-2014, 09:42 AM   #11
how about ISO and aperture?it must have changed one of those then.
04-17-2014, 11:15 AM   #12
I went back and checked each shot and the camera did change shutter speed and aperture for each bracketed shot. I just never noticed it before.
Do you have your ISO set to auto instead of you changing it? Mine is always set so I can choose which ISO I want to start out with, then the camera changes it as it sees fit.
04-17-2014, 03:01 PM   #13
Mine's always set manually. And now that I'm home, I can't seem to repeat the issue. Perhaps I was inadvertently hitting something to reset the bracketing back to the original value? I'll keep toying with it.
In any case, it seems to be working as it should now...
k-30, k-50, pentax k30, pentax k50, shutter
Odd shutter issue - "firmware 1.0" problem? WillWeaverRVA Pentax K-3 119 06-16-2014 08:48 AM
Pentax ME shutter speed vs meter issue klphoto Pentax Film SLR Discussion 7 10-26-2012 11:39 AM
Odd hotkeys issue? Ratmagiclady General Talk 3 05-22-2011 11:20 AM
Pentax KX Shutter starting to stuck at slow shutter speed. Spirit722 Pentax Film SLR Discussion 7 03-03-2011 09:49 PM
K-x Av with auto-ISO: slow shutter speed issue Karellen Pentax DSLR Discussion 6 02-22-2010 03:58 PM
All times are GMT -7. The time now is 05:50 PM. | See also: NikonForums.com, part of our network of photo forums!
