Originally posted by tuggie76 Yes, but in confined spaces you need wider not longer, in my front room I have to stand at the opposite end to get a full length picture and it's almost impossible to get a group shot.
Tuggie76
That's why the 50mm isn't suitable for a lot of indoors activity, and the 35 might even be too tight sometimes. this is where some short zooms really prove their worth.
Yes, the 16mm end of the DA16-45 zoom is pretty wide, you'll have to check it out. By the time you get mid-range on that lens - around 28mm - it's good for isolating individuals. For the price, I maintain the 16-45 is worth considering - certainly it's quite flexible.
Wider than the 16mm of the 16-45 and you're into specialty lens territory. I have a 10-17 which isn't super-fishy at 17mm, but much wider than the 16mm. I suppose I'll have to do some comparison shots this spring once the gardens are blooming... I don't have a 10-20 or 12-24 to compare it with, though.
