Originally posted by Steve.Ledger Sounds plausible I suppose.
Except this doesn't happen with the K-7 and probably not the K-5/K-5ii which is why I didn't expect it to happen with the K-50.
Does it happen with the K-3? Because it's really annoying actually.
Based on the hacking thread these are quite different cameras software and processor wise. The newer K-30 upwards, so K-50 and K-3 are based on a different CPU type, so the concept of the code will be the same, but there will be differences. However it's likely to be a different take on how they should behave.
One could also ask why it's fixed at/defaults to f4 for liveview? I assume there is a reason, but ideally the screen should show what's actually going to be recorded?
