Originally posted by haviet Also, any suggestions on prime lenses for typical everyday use? I am thinking the 35mm f2.4 for $140? Anything else? I don't mind the used market there are other/better options?
The DA35/2.4 is a very good use of your money. If you go wider with AF the price goes up.
The DA50/1.8 is a good buy too. But it's somewhat close in focal length to the DA35/2.4. It's worth getting a used FA77, or at least a DA70, if you can. Expensive, but worth it.
Here are the best-value Pentax lenses I've found - very good IQ but affordable. Some are a bit harder to find:
F70-210/4-5.6 (either Pentax or Takumar version)
F24-50/4 or A24-50/4
Cosina 100/3.5 macro (sold under many brands, in both MF and AF versions)
M or A100/2.8 (non-macro)
A50/1.7
Also:
F or FA135/2.8 (it costs more than the others, but has AF and it's a wonderful and small lens)
Aside from what I've already mentioned, two other lenses that are worth spending way more than you originally anticipated are the DA*50-135/2.8 and the DA*55/1.4. Either one of them - or the FA77 - is a good enough reason by itself to buy a Pentax body. Likewise with the M or A100/2.8 (and possibly the F/FA135/2.8), truth be told. And you don't need to upgrade your body to take advantage of them - the K-30 is great enough already.
