05-28-2014, 07:27 PM   #1
K-30 - Blurry Sides
Hello all!
I have a problem with my K-30 photos. I noticed that for some of my landscape images, the left/right side would be slightly blurry while the center remains in focus. The photos below are what I have taken that have this issue.
I am using a clean 18-55mm lens, set the aperture at least f/8, the auto active area is 5 AF Points, the Contrast AF is Spot, and have auto focus enabled. Any clue on how to resolve this issue? Thank you!
05-28-2014, 07:31 PM   #2
You said at least F8- if you venture much higher, you'll be able to observe softness due to diffraction. Distortion correction may also introduce softness.
05-28-2014, 07:52 PM   #3
calsan's Avatar
Seriously hard to tell from that type of photo, because it's hard to see where you focused and if it's just wind in the trees and grass. Trees move a lot more than most think, so a high shutter speed is really required for perfect sharpness.
Maybe you're rotating the camera a bit when you click the shutter (i.e. too hard click!) - the centre would rotate less than the outer and so stay sharp, but the greater distance moved on the edge of the photo would induce blur at the edges.
05-28-2014, 10:00 PM   #4
EarlVonTapia's Avatar
QuoteOriginally posted by LPrime Quote
Hello all!
Attachment 224161
Attachment 224163
Attachment 224164
That may just be a natural characteristic of that lens. If you check this site: Pentax SMC DA 18-55mm f/3.5-5.6 AL WR - Lab Test / Review - Analysis and scroll down to the MTF resolution charts, you will see that the corner and edge sharpness never ever really approaches the sharpness at the center, no matter the focal length and aperture.
Better lenses will have more even resolution across the frame, but they are more expensive. A cheap one that has good sharpness throughout is the DA 35 f2.4.
This is why I sometimes shoot a landscape scene with the intention of cropping out the edges/corners.
05-29-2014, 09:44 AM   #5
Thank you for the reply guys. It's kind of strange because on my K-X, it almost does not have this type of issue.
In response to Adam, that may be the case, but I checked out some of my other landscape images that are set on various f stops (usually from f/5-f/16) but I still get the blurry sides on some photos.
In response to calsan, the photos were taken at a higher shutter speed, so it doesn't have the motion blur, rather the blur appears to be gaussian.
In response to EarlVonTopia, that may be the case as well, but I have the same lens for my K-X and it never seems to have the issue, just on my K-30.
Perhaps there could be certain settings that I am not aware of that would allow me to capture entire landscape scenes more sharply.
The 2 cropped images below are in one same picture. Top is on the center of the image and the bottom is on the right. Taken at f/8, 1/500 shutter speed, ISO 200, and focal length is 23.
Name:  IMG 044-2.jpg
05-29-2014, 02:08 PM   #6
I think I might have solved the issue.
I shot some landscape photos today with the focal length at 18mm and I noticed that when I use autofocus, it doesn't always go to infinity focus, which results in the issue when the left/right side becomes blurrier than the center of the image. So when I manually adjust the focus to infinity, every part of an image I take seems to be clearer than before, including the right/left side.
From now on, I'll keep in mind about infinity focus when I decide to take clear landscape shots.
05-29-2014, 02:20 PM   #7
Try altering the K-30 micro focus adjustment, I've found adjusting for best infinity sharpness is better than using AF charts indoors with some lenses.
05-29-2014, 11:45 PM   #8
QuoteOriginally posted by SteveB Quote
Good idea. I'll be sure to do that.
af, auto, focus, issue, k-30, k-50, pentax k30, pentax k50, photos
For Sale - Sold: KatzEye Split-Prism Focusing Screen - for K-3, K-5, K-5II, K-7, K-30, K-50 & K-500 chickentender Sold Items 7 04-15-2014 08:35 PM
Pentax K-3 Random Blurry Image Theory Qwntm Pentax K-3 24 01-03-2014 11:47 PM
HUGE instant rebates on K-01 (8/30-9/30) cheekygeek Pentax K-01 6 09-12-2012 08:05 AM
Korean K-30 Focus-Peaking Test (and Overall K-30 Review) Welfl Pentax K-30 & K-50 8 08-23-2012 01:06 PM
for fun: two sides heard from Nesster General Talk 4 06-09-2012 08:01 AM
All times are GMT -7. The time now is 06:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
