05-31-2014, 12:44 PM   #1
Pentax K-30 pictures are getting Dark
Hey Folks,
Greetings from Egypt , the country where there is NO Pentax distributors
I have got my K-30 around year and half ago, and it works really great but suddenly it began to have some issues with Exposure!!
I am getting dark pictures "almost black" all the time using my AF lenses (FA 28-200mm & DA L 18-55mm)
but when i try my MF lenses (M f/2 and Ricoh f/1.4) adjusting the aperture ring pictures come out normally bright.
So i suspect that the problem is in my Aperture motor inside the body, I have read many threads regarding the same issue, so it seems that its a common problem in the K-30
And to make sure of my assumption i used my (FA 28-200mm) twice, once using the apreture ring it worked fine ,and then adjusting the aperture from the body it became dark again.
1.So is there any solution foruch a problem?
2.What could be the reason behind that? im using my camera really wisely and i dont remember if it ever felt down or got hit
05-31-2014, 01:33 PM   #2
Edit:
Holy crap, I wish everyone used that size. Makes reading on a phone so much easier!
I'd agree with your diagnosis. Sometimes, electronic devices just quit - but I'd suggest resetting the camera to make sure it's not just some setting.
05-31-2014, 02:45 PM   #3
6BQ5's Avatar
I have heard that dark images may happen when the lens contacts become dirty. They communicate the wrong aperture setting as the aperture lever on the lens is lowered by the camera during the picture taking process. The camera thinks the aperture is more open than it is so it closes a bit more than it should.
06-01-2014, 06:31 AM   #4
Clean the contacts on the mount and the lenses
06-01-2014, 06:37 AM   #5
QuoteOriginally posted by felixkh Quote
What is the best way to clean them? is there any special kind of liquids i should consider?
06-01-2014, 07:19 AM   #6
6BQ5's Avatar
QuoteOriginally posted by islamnassar Quote
I would start simple and work my up the scale. Use a dry cloth and see if any grime or oil runs off. Some people have gently rubbed an eraser because it is ever so slightly mildly abrasive. You could probably use a drop of mild solvent/cleaner like lens cleaner on a clean cloth.
I only had to do this once when I was out shooting. All I had was my shirt and when I rubbed it around the contacts I left a black smudge on the fabric.
10-16-2015, 09:34 AM   #7
Were you able to overcome the issue ? I am facing the same problem with my K 500 now..How can I overcome this issue ?
10-18-2015, 09:17 PM   #8
I'm actually having the same issue with my Pentax K30.
As they recommended, I cleaned the lens contact points with a microfiber cloth on it.
My camera is performing once again as before.
10-20-2015, 04:50 PM   #9
DAMN DARK IMAGES, I FIND that letting it shoot in multi exposure mode always fixes it
03-07-2016, 10:21 AM   #10
If I switch to Live view it fixes it for me
06-02-2016, 08:44 AM   #11
QuoteOriginally posted by mellowyeahlow Quote
I tried that.. at the end.. I almost ended up buying K50.. But found a service shop which did the fixing for $125 USD. It ran great until last week. Again the problem looks to be returning.. occasionally getting dark images.
---------- Post added 06-02-16 at 09:16 PM ----------
QuoteOriginally posted by Dids2 Quote
Yeah LV worked for me too.. But it couldn't continue for long since the Aperture problems continued to diminish making the LV pictures out of sorts in terms of colors, brightness and everything..By the end the pictures started looking like as if.. I have taken it with a stupid 1 MP phone camera..It surely is the issue with lens contacts.
06-02-2016, 09:11 AM   #12
Only way to get rid of the problem is to take rapid photos repeatedly until the aperture ring starts opening as it should. Some days it will take forever to get it started, while others it will be ready to go within 5-10 pictures. But thats the only solution I found for my K30.
I am going to wait for the K30 to die. Then I'll think about which company I should stick with. I might jump ship to Nikon/Sony. Or I might just save for a while and try to get a K1.
06-03-2016, 01:51 AM   #13
I agree much easier to read
---------- Post added 06-03-16 at 04:53 AM ----------
oh it will die trust me
06-03-2016, 07:07 AM   #14
Yeah.. I feel that way too... Only Worry I have is when switch the lenses.. That's when I find the problem worsening..... as you said, I think I just have to live with it or buy a lens with everything in it... But I am content with Pentax for its features at such low price.
06-03-2016, 11:57 AM   #15
QuoteOriginally posted by tosudarshana Quote
Dont worry the aperture motor will surely die just like it did on mine about three months later
28-200mm, aperture, body, dark, error, fa, images, issue, k-30, k-50, k30, lens, lenses, lv, pentax, pentax k30, pentax k50, pictures, underexposure
K-30 Battery Life, what are you getting ?? tammons Pentax K-30 & K-50 111 09-16-2013 12:34 PM
K-30 after accidentally getting wet ASheffield Troubleshooting and Beginner Help 10 08-20-2013 05:22 AM
My experience with the Pentax k-30 @ B&H (BIG PICTURES) JinDesu Pentax DSLR Discussion 19 02-24-2013 11:26 PM
Misc Getting used to the K-30 loco Post Your Photos! 22 08-08-2012 06:03 PM
Pentax K-30 Pictures Adam Pentax K-30 & K-50 15 07-02-2012 04:25 PM
All times are GMT -7. The time now is 11:34 PM. | See also: NikonForums.com, part of our network of photo forums!
