Originally posted by jjuanmartin Hi guys I got a K50 a few days ago.
I'm familiarizing with all it's features, I'm quite impressed with it's video quality.
Putting aside Image Stabilization. Talkin about highlight and shadow correction usage. Does it worth to have them on?
I think this wont help if we're looking for natural shots. I must say I couldn't test it out carefully yet. I think I'm going to do some portraits to compare.
What do you gusy think?
Thank you in advance
The best way to test is with a scene shot without protection using the entire histogram
Shots must be in JPEG.
Meter using matrix metering on the scene with neutral settings for saturation, contrast etc in manual mode with the green button. ISO must be a minimum of 2x the cameras minimum ISO . Take one shot with corrections off, another with corrections on, without changing the shutter , aperture or ISO . Best to be tripod mounted to ensure exactly same image etc...
In a photo editor, that can measure greyscale and histogram on a selection (as opposed to the whole frame) select specific spots with different exposure in the original frame and then measure the same points exactly in the one using protection. You will likely see up to 45 greyscale value between the darkest and latest points of the pair of images representing at least 1 stop of additional dynamic range for both the light (half above 120 ) and dark (half below 120) parts of the total histogram.
If memory serves me correctly, neutral points ~120 greyscale remain neutral
What actually happens is the middle portion of the histogram is compressed from 45 to about 30 greyscale value per stop, reducing contrast, increasing the apparent dynamic range of the shot, but, note this can also lead to color banding if you make further adjustments to the image with a JPEG editor.
Sometimes it works sometimes not, depending upon the range of colours especially clear blue skies with small changes but finite across large areas
