Originally posted by ramseybuckeye You don't use the self timer, the interval does the timing, you may miss being in the first shot unless you trigger with the remote (not sure the remote works to start in interval but it should). Read the instructions carefully in the manual and practice once or twice. There are a lot of steps but once you've done it it is pretty easy.
Thanks. I had thought of that, and it's easy enough to set up, but it sure seems like a kludge work around, especially if other manufacturers provide the actual functionality. I guess I could set the interval for 3 sec and maybe 6 or 7 pics, I won't be in the first one and the next two would be of me running back and getting settled...
I tried the remote and it doesn't work either, you have to push the button manually to start the interval.
Thanks everyone for your replies. I think I understand what needs to be done, although it isn't the answer I was looking for. The remote with a 3 sec delay (to put the remote down) seems to be the best solution, assuming I have the remote with me and I'm close enough to use it.
