09-13-2015, 10:12 PM   #76
My k-50 is blind after one year ! :-(
I proudly bought a k-50 last year.
After one year of use, it died.
It's impossible for me to take any pictures anymore !
Live View seems to take pictures but not for so long.
Impossible to make focus… It died, too.
So, this weekend, I took pictures with my iPad…
What will I do with my k-50 and all the lenses I bought ????????
The exposure meter doesn't work anymore and pictures are now always under-exposed even
with a 5 seconds exposure during the day !!!
I don't recommend this camera !!! :-(
09-14-2015, 03:28 AM   #77
For what it's worth, if your still under warranty return it for a fix. I understand your rant. It shouldn't happened if you use it as it should be used, without abuse.
09-14-2015, 10:59 PM   #78
Uhhh… What do you mean by "It shouldn't happened if you use it as it should be used, without abuse." ????
09-15-2015, 12:58 AM   #79
Well, just shooting pictures to the death is using normally, Dropping it, submerging it or using it as hammer or something else which isn't taking pictures in the normal course is abuse.
Like I said, I understand your rant. You expect a camera to work as a camera and not give you trouble.
09-15-2015, 01:23 AM   #80
awaldram's Avatar
QuoteOriginally posted by SteveB Quote
I've never heard of any K-30s with this problem.
All cameras will flop if the mirror gets out of sync with their shutter.
This is standard recovery behavior and both Nikons and Canons will do the same.
The k3 had a possible internal calibration issue that triggered a reset even when not required and so generated all the attention.
But any camera will flop if it detects a reset issue but the flip doesn't recycle the sync so will flip again.
My K5 had it mirror box replaced at 53,000 actuation's because it would flop because the motor gear chain was worn.
09-15-2015, 04:53 AM   #81
NS_Sailor's Avatar
I own a K500 which is the non-weather resistant cousin to K50 and I haven't experienced any issues with mirror flop as of yet. I use both new and legacy Pentax, Sigma and Tamron lenses on the camera under a wide range of weather and temperature conditions.
After reading the posts and from an engineering point of view, I'm of the opinion that the mirror flop issue could be the result of changes made the front lens mounting ring and or lens lock pin on the K50 body to accommodate and provide sufficient compression on the lens seal to the camera body. If this were so the difference in design tolerance between the 2 rings or lens lock pin could be enough to put both the lens contacts and the aperture lever on some non-weather resistant legacy or after market lenses out of optimal alignment. Where there is also potentially a wide tolerance in the manufacture of a lens K-mount ring from different suppliers, including Pentax, this could also explain why problems are experienced with some lenses while other lenses work without issue making it a real hit and miss issue to solve.
01-09-2016, 04:59 AM   #82
One good year of K-50 use, now mirror flop
Thanks to all for their insights. To add to the data in this thread, my wife bought me the K-50 from Costco for Christmas 2014, and I have loved it, taking several thousand photos with no problem at all. I just purchased a Tamron lens with Pentax mount to add to my telephoto capability. A few weeks later, without any warning, the camera started double exposing images and the mirror would double and triple flop on every image, and the software would lock up. I tried adjusting every aperture and focus setting, but it had no effect. I find that if I switch lenses, I can sometimes get the aperture apparatus to work normally, giving a crisp image. But within 3-5 such normal shots, it goes back to having its problems. I don't think there is any causality between the flopping and the Tamron lens, but I mention it here in case it adds to the general understanding of the issue. I have cleaned the lens mounts, but that does not seem to have much impact. I have written to Ricoh Imaging online support to ask them if replacing the "Diaphragm control block [NM D13-301]" will address the problem, as was reported by another user. Thanks.
04-29-2017, 06:22 AM   #83
My K50 has developed the faults described in this thread, namely camera controls freezing, and more recently, the mirror freezing (or flopping?). The shutter count is 7000 approx. The camera was bought used, and is out of warranty. The problems only occur when the lens is attached. The lens is a Pentax 18-135. So basically, have there been any developments regarding this issue since the last post in this thread? Have repairs been successful? And what it is going to cost me to get it repaired, or should I just start again.....with another brand of camera, as I've lost faith in Pentax.
04-29-2017, 07:58 AM   #84
QuoteOriginally posted by mikeirl Quote
Go to Canon and make up for their having lost me, after I had two straight Canon Rebels totally die - both had processor issues. {combined shutter count 4352}
Regularly someone will say "I've lost faith in Pentax", but honestly, the others aren't any better.
04-30-2017, 06:35 AM   #85
QuoteOriginally posted by reh321 Quote
I may as well just stick to using my phone, then...............
04-30-2017, 06:47 AM - 1 Like   #86
All mirror based slrs will have a strong chance of being affected, this is mostly related to chinked gears, usually happens when the camera is knocked hard or has hit something hard. You might consider a mirrorless camera, as they dont have mirrors, but the tradeoff would be lesser low light focusing or non shots altogether. There is only 1 mirrorless that can take your lens, the quite capable K01, or just sell your lens and delve to another brand, hmm I would recommend you a Panasonic G7 or the chinese Y1 M1, both take 4/3 lenses, which are very good and not expensive..
adapter, backup, batteries, battery, camera, drop, eneloops, firmware, k-30, k-50, k-r, k200d, k50, lens, lenses, mine, mirror, pentax, pentax k30, pentax k50, pentax k50 mirror, pm, post, power, shots, weather
For Sale - Sold: Pentax k50 body WILLIAM HUBBARD Sold Items 5 04-09-2014 10:41 AM
Mirror Flopping - How Much To Repair Pentaxiac Pentax K-5 3 08-17-2013 01:30 PM
Here's another mirror flopping issue minahasa Pentax K-r 0 07-23-2012 10:30 AM
Mirror flopping when metering w/ green button and old m42 lens Philoslothical Troubleshooting and Beginner Help 15 10-22-2011 05:06 PM
All times are GMT -7. The time now is 11:43 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
