08-17-2014, 09:50 AM   #1
K30 strap goes to pieces
Original neck strap have started to crumble after 8 months use only. My camerabag is full of those tiny black particles coming from neck strap. They go everywhere...like inside camerabody, lens caps and lenses! I loose my mind soon.
Anybody else experiencing this?
08-17-2014, 09:58 AM   #2
crewl1's Avatar
I have not used the Pentax strap on any of my cameras.
Guess they are as cheap as I thought.
08-17-2014, 10:19 AM   #3
KevinR's Avatar
Yes. I had this on my K200-D. It is the rubberized felt lining of the strap only. And I suspect in my case it was due to sun-screen products chemically denaturing the rubberized lining. It let go after carrying it around my neck on several sunny hikes. I got quite a surprise with the black particles coming off all over me during the hike and it took a while to realize the cause.
To fix, I took a brass wire brush suitable for cleaning suede shoes and rubbed off the entire lining. All good now. Just not quite as smooth as before.
Hope this helps.
08-17-2014, 10:24 AM   #4
severalsnakes's Avatar
No talkin' mess!
I bought a ZX-L (film) body back in 2003 and a K-30 body in 2013. I have been using the straps that came with the bodies almost exclusively (I recently removed the strap on the K-30 to just use a wrist strap for a while, but that is temporary). Neither the 11-year old ZX-L strap nor the 1-year old K-30 strap is crumbling... HOWEVER, I know exactly what you're talking about, because I bought a used Pentax strap from KEH on Ebay that was visibly cracked and is now leaving dirty black crumbles all over everything, especially my SKIN, when I wear it around my neck. The "used" strap from KEH looks like it was kept in storage, doesn't look like it was actually "used", so I wonder if heat/temperature changes have degraded the materials. It doesn't make much sense because my ZX-L strap has been to hell and back and it is in great shape...
Unfortunate circumstances, I guess...
08-17-2014, 02:13 PM   #5
Banned
Never used the Pentax straps, too narrow. I used to use my old felt lined cloth straps from the film era in the 70's, never had that problem. My *ist DL still has one, My K20 & K30 now hang from a BlackRapid Strap, either the Yeti, or the wrist strap. Both very comfortable to use.
08-17-2014, 04:07 PM   #6
This is my favorite style of strap that I use on my cameras. Unobtrusive, low cost, durable, and just has a nice little rubber cushion contacting my neck that doesn't soak up sweat or wear out.
08-18-2014, 02:01 PM   #7
ejhc11's Avatar
Try this company for replacement
I also use BlackRapid straps for long carries as it really takes the weight of my neck.
08-18-2014, 07:54 PM   #8
ScooterMaxi Jim's Avatar
Depending of the situation and lenses to be used, I stick with a wrist strap or a BlackRapid attached to the tripod mount. Either way, easy to switch. Best of the wrist straps I've found is the basic Joby - plenty strong and no way you'll drop the camera.
Amazon.com : Joby JB01271-PWW DSLR Wrist Strap (Charcoal) : Camera Wrist Strap : Camera & Photo
08-21-2014, 07:23 AM   #9
Yes looks like heat was causing my strap go peaces, raining season have started so no more sunny hot here and my k30 strap is back normal.
08-23-2014, 07:26 PM   #10
whk1992's Avatar
I got my camera two days ago and glad that I read this post. Now, I'm keeping the Pentax strap in its original package and use my homemade strap with an eyebolt to the tripod socket.
08-23-2014, 07:35 PM - 1 Like   #11
timmijo's Avatar
I just bought a strap from the Couch company that makes camera and guitar straps from recycled automobile seatbelts and upholstery. Made in USA. I love it! https://www.couchguitarstraps.com/camera-straps.html. I got the "Seatbelt" strap in "mellow gold" to go with my new black and white K-30. Awesome! and affordable.
08-23-2014, 10:35 PM   #12
QuoteOriginally posted by timmijo Quote
Damn, those are CUTE! and not too expensive, either! Thanks for sharing. :-)
09-04-2014, 04:26 PM   #13
Lokusart's Avatar
have you used repellents with DEET content? this chemical is bad for plastic and rubber
k-30, k-50, neck, pentax k30, pentax k50
Camera Strap for the k30-k50 kshapero Pentax K-30 & K-50 37 04-12-2014 01:48 PM
A sad day as the K30 goes back... Damian.T Pentax K-30 & K-50 27 03-03-2013 07:41 PM
K5 - falls to pieces ThorThum Pentax K-5 75 07-31-2011 09:49 AM
Goodbye to neck strap; Hello Wye Strap!!! philbaum Pentax Camera and Field Accessories 42 08-12-2010 01:39 PM
Strap to replace standard strap Mann Pentax Camera and Field Accessories 14 06-03-2009 09:35 PM
All times are GMT -7. The time now is 07:48 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
