No, what I meant was moving the lens beyond the 70mm mark into macro, which in realty is a shorter focal length. So you're still wrong in your previous statements, I quote you "
and it goes closer only at 70mm FL!". No it does not go closer at 70mm it goes closer to .32cm by moving to lens beyond the 70mm mark into the shorter focal lengths of the macro portion of the lens. When moved in macro mode the lens focal length moves back towards the shorter 35mm focal length to about half the len's extension at maximum macro, to a close up of 1:4 magnication ratio max.... So it is not closer at 70mm PERIOD.. Don't believe me if you have a copy move it past 70mm and watch the lens extend to a shorter focal length.... The minimum focus distance for any lens is the complete minimum focus distance that lens will go as stated in the specs for the lens.
Sorry for taking this slightly off topic but this is the second thread this member is putting forth incorrect information.
