09-16-2014, 09:57 AM   #1
timmijo's Avatar
Quickest way to change ISO when using focus point
Hello.
In choosing a focus selection point with the four-way arrow button on the K-30, is there a quick way to change ISO other than going into the menu or info button? (The "up" arrow button is no longer for ISO while focusing this way.)
Thanks
09-16-2014, 10:02 AM   #2
normhead's Avatar
What about TaV mode? Let the camera do it.
09-16-2014, 10:18 AM   #3
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by timmijo Quote
I used to just put a different film in, it worked well that way for years.
09-16-2014, 10:26 AM   #4
Swift1's Avatar
You should be able to program on of the e-dials to ISO control.
09-16-2014, 10:55 AM   #5
Set the right button customisations and in Av mode you can set ISO with the front wheel and toggle between Auto ISO and manual with the green button and wheel.
09-16-2014, 11:00 AM   #6
aleonx3's Avatar
Why not change to auto ISO on the fly by hitting the green button? P mode is properly the easiest, you control shutter on the front dial, control aperture on the rear dial and then hit the green button, you get TAv mode...
09-16-2014, 11:12 AM   #7
jatrax's Avatar
Program your e-dial. I have mine set so the front dial is ISO in all modes that offer that. So in Av mode front=ISO rear=aperture. in Tv mode front=ISO rear=shutter speed
09-16-2014, 12:15 PM   #8
timmijo's Avatar
Thanks for the replies; I will get to working on it. I just had a blast in Program mode this morning (which almost made the K-30 act as a point-and-shoot) but sometimes I do not remember what I did to get the settings to do that. It's a fun ride, though, upgrading to a K-30 from a K-r.
09-16-2014, 04:26 PM   #9
Using auto iso is a problem when you need everything to stay the same. I shoot a lot of my daughter's indoor volleyball. With contrasting uniforms, white balls, varied backgrounds, the exposure gets fooled.
So, I set everything to manual and go. With limited indoor lighting, I do have to tweak things. I too use the selectable focus points as it's better to focus on the lower part of the body than the face.
I just hit the info button, turn a wheel to 5 point, select ok, make the iso tweak, then switch back. It's kind of a pain, but does work getting the exposure dialed.
QuoteOriginally posted by aleonx3 Quote
09-16-2014, 07:17 PM   #10
aleonx3's Avatar
QuoteOriginally posted by ziscwg Quote
OK, I am sorry, I don't have the k-50 nor the k-30.... may be that is the work-around. Are you using matrix metering mode? and you select AE locked regardless of AF points? and you can also limit your auto-ISO to under 800 or 1000, and you can also use EV compensation... many ways to skin a cat; you just need to use the methods convenient to you... without having to go through heaps of manual settings (advantage of Pentax DSLR).
09-17-2014, 04:57 AM   #11
Banned
Hello.
Thanks
Check pg.165 in the manual, "Setting the Raw/Fx Button, AF Active Area", perhaps this may help. Or, pg. 103, you can hold the "OK" button to toggle "select" off / on, returning use of the 4-way buttons.
arrow, button, change, change iso, focus, iso, k-30, k-50, pentax k30, pentax k50
Kr: short contacts to change aperture when using M42 lens ? icy Pentax K-r 27 09-04-2016 10:54 PM
Focus Magnification When Using Quickshift: Impossible? Doundounba Pentax K-01 7 03-13-2014 06:59 PM
How to focus when using a tripod Hattifnatt Photographic Technique 6 05-20-2013 01:50 PM
Pentax 55mm 1.4 Point to Point Focus Speed MBT74 Pentax SLR Lens Discussion 22 10-16-2012 06:35 AM
[K20D] Does your SR icon light up when using the AF button to focus? Reportage Pentax DSLR Discussion 4 09-18-2010 10:46 PM
All times are GMT -7. The time now is 08:27 AM. | See also: NikonForums.com, part of our network of photo forums!
